Welcome to the North American Subaru Impreza Owners Club Wednesday August 20, 2014
Old 12-03-2008, 02:00 PM   #376
paul_p1
Member#: 77372
2005 Spec C
WR Blue
I've just been informed by my mapper that ECUTek cannot return my ECU(Flash 2002) JDM STI SPec C to a pre-ecutek state, this has locked me out of my ECU. Rediculous!!
paul_p1 is offline   Reply With Quote
Old 12-03-2008, 02:23 PM   #377
Daluv
Member#: 159325
ghey
but you can try the easyEcu trick:
All you need a someone with a easyECU and a stock rom file. Flash it over and your done.
Use Cobb or open soruce.
Daluv is offline   Reply With Quote
Old 12-03-2008, 03:35 PM   #378
paul_p1
Member#: 77372
2005 Spec C
WR Blue
What's easyECU? I'm in the UK btw. I'm fuming, just contacted ECUTek directly.
Old 12-03-2008, 03:42 PM   #379
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
EasyECU allows you to switch maps. I have it myself.
CoolRex is offline   Reply With Quote
Old 12-03-2008, 05:39 PM   #380
Manutd06
Member#: 193616
06 WRB
WRX
woww guys, im like freakin worried as hell now.......my tuner at the dealership just did stage II on my car and guess what, he used ecutek for the tuning (both my stage I & II). so should I be having heart attacks just about now. one thing i know for sure, if anything happens and i need to go bak to stock, he'll do watever that needs to be done. thats the reason im going thru a dealership to begin with instead of a private shop.
Manutd06 is offline   Reply With Quote
Old 12-04-2008, 07:16 PM   #381
Vicious LSD
Member#: 103539
2005 WRX FP 18G!
MSPT Tuned!
I was also told from my tuner that it is not 100% that you can flash your car to stock and be unlocked. There has to be some legal way to deal with this! No notice to the customer or tuners.
Vicious LSD is online now   Reply With Quote
Old 12-04-2008, 10:49 PM   #382
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
I read somewhere that Cobb AP can now clear ECUTEK licence (lock) codes from the ecu. All you need is the latest AP software, marry the AP to your ECUTEK'd car, flash a stock rom with the AP, then unmarry the AP.
Once the AP is unmarried, you can then proceed to flash your own tunes using ECUFlash.
This is what I read on the openecu forums.
wrxsti.l is offline   Reply With Quote
Old 12-05-2008, 01:40 PM   #383
Vicious LSD
Member#: 103539
2005 WRX FP 18G!
MSPT Tuned!
How would that work if ECUTek alters the handshake protocol? I hooked my car up the ecuflash and it isnt even able to connect to the ecu.
Old 12-05-2008, 02:39 PM   #384
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
FYI Cobb does the same thing though. However you can revert it.
Old 12-05-2008, 02:43 PM   #385
paul_p1
Member#: 77372
2005 Spec C
WR Blue
I'm getting no where with ECUTek, looks like I'm having to shell out for a new ECU. You think I'd get anywhere if I sent them an invoice for the new ECU??
Old 12-05-2008, 02:45 PM   #386
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Not at all.
Old 12-05-2008, 02:59 PM   #387
paul_p1
Member#: 77372
2005 Spec C
WR Blue
Yip.
On a side issue, I didn't realise that ECUFlash/Romraider were hacked versions of the ECUTek software.
Old 12-05-2008, 04:17 PM   #388
LastResort
Member#: 99289
They are not.
LastResort is offline   Reply With Quote
Old 12-05-2008, 04:27 PM   #389
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Originally Posted by LastResort View Post
They are not.
Originally they were. Now they aren't.
Old 12-05-2008, 05:22 PM   #390
LastResort
Member#: 99289
The XMLWrite application was based off(contained) of hacked EcuTek information, but EcuFlash only used those files.
Old 01-02-2009, 07:25 PM   #391
Vicious LSD
Member#: 103539
2005 WRX FP 18G!
MSPT Tuned!
Has anyone gotten a solution to get the ecutek ecu opened or flashed back to stock and it worked?
Old 01-03-2009, 03:01 AM   #392
06STi
Member#: 97561
2006 Widebody
WRB/Carbon/Primer
Find someone local with ecutek deltadash. Get your old tuner to gve you your stock rom file back. Then take the Delta Dash and flash your ecu back to stock. Done Deal.....
Hell. I have unflashed ecutek, tuned my car with rom raider, Then just flashed ecutek back for another shop to retune my car on the dyno.
You can flash ecutek off. My car didnt have any problems once I flashed it off with the stock rom file.
06STi is offline   Reply With Quote
Old 01-03-2009, 10:44 AM   #393
Vicious LSD
Member#: 103539
2005 WRX FP 18G!
MSPT Tuned!
what if it gets flashed to stock via ecutek tuner? I was told it may be a 50/50 chance
Old 01-03-2009, 11:17 AM   #394
Zumble
Member#: 34860
2005 Forester CGM
Which dealership? North Coast? Metric?
Zumble is offline   Reply With Quote
Old 01-03-2009, 02:29 PM   #395
06STi
Member#: 97561
2006 Widebody
WRB/Carbon/Primer
Its simple. Go to the Ecutek dealer demand its removed. They can remove it. They drag it out and play games with you just to keep you as a customer.
It can be removed.. I have removed and reinstalled mine a few times. Using differant tuning software between. If they "cant" removed it. And you signed nothing before installing or tuning stating that ecutek has ownership over your ecu. Take them to court. They will lose. Everytime.
Old 01-05-2009, 05:58 PM   #396
Vicious LSD
Member#: 103539
2005 WRX FP 18G!
MSPT Tuned!
any updates on a ecutek crack?
Old 01-06-2009, 08:06 AM   #397
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Just buy another ECU. Used they are cheap.
Old 01-07-2009, 12:25 PM   #398
Benchmark Tuning
Member#: 154444
2008 08 STi, Typhoon
06 STi, 847-960-8676
any EcuTek dealers should unlock it for you no problem. I know al (DynoFlash) does it if you send him the ECU, there are other places as well that tune them that shouldn't have any problem unlocking the ECU for you
Benchmark Tuning is offline   Reply With Quote
Old 01-07-2009, 02:02 PM   #399
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Contact siegelracing@gmail.com and state your year and make and let him know exactly what you are wanting. If he can do it he will let you know.
Old 01-23-2009, 08:49 AM   #400
RR-racing
Member#: 41632
2004 Spec C
WRC blue
I realize that people are upset about not being able to reflash their ECU's with another source after its been Ecutek flashed... but you must understand Ecutek is protecting their intelectual property in a sense (although I feel there should be a work around for a dealer to take an ECU back to stock).
I've spoken to Ecutek several times about Open Source tuning. I am personally torn both ways. Their arguement are as follows:
(1) Ecutek spends significant time development the maps and software.
(2) Open Source is flat out ripping and stealing their maps and software. They are not doing the work themselves.
I also see comments on this and other forums blatantly discussing ripping of Ecutek software, which quite frankly are quite troubling that people quite openly, see absolutely nothing wrong with doing that.
On the other hand, I must say that I do not have a whole lot of experience with these ROM editors to say if they are simply editors that allow you to do what you want, or they really are blatant rips of Ecutek software/maps.
Rafi
RR-racing is offline   Reply With Quote
Warning: Do not tailgate an RV towing an SUV. cwareing Vancouver Impreza Club Forum -- VIC 8 07-09-2007 06:43 PM
Reminder: Do not purchase Maxtor drives. aod Off-Topic 81 03-01-2007 07:25 PM
60mphn4 - If this is your liscense plate, read this linux>windows Mid West Subaru Owners Club Forum -- MWSOC 19 10-10-2005 05:20 PM
Thinking about an APS catback for your STI? Read this first. WRXIN Factory 2.5L Turbo Powertrain 11 02-24-2004 09:36 PM
