Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 06-17-2006, 02:24 PM   #1
kams#3
Member#: 106737
05 sti
silver/carbonfiber
Default Stand alone instal
hey guys i am placing the order today for my perrin GT30R with Hydra and wideban. i will be installing the turbo kit mtself but i was wondering if anyone has installed the stand alone em (hydra). is this something i can do, or is it to technical with the wiring and sensors?
thanks
kams#3 is offline   Reply With Quote
Old 06-17-2006, 02:45 PM   #2
keaniegenie
Member#: 94494
2005 Element 92x
bboy is probably your best reference for that. At least for a member. Of course, Phil is always a good person to chime in on.
I'm getting my Hydra installed now as we speak
keaniegenie is offline   Reply With Quote
Old 06-17-2006, 07:52 PM   #3
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
If you bought it new it will come with instructions. It's very simple to install. Just remove your negative bat. terminal, remove passenger side carpet, unplug the stock ecu and remove it, plug in hydra harness, plug harness into hydra, T into a vac line on the manifold and run that line to the Hydra MAP sensor. then just load a map and you are done.
-Dan
suby_dude is offline   Reply With Quote
Old 06-18-2006, 12:53 PM   #4
Tuning Factory Inc.
Vendor
Member#: 3600
Actualy the Hydras usually come with a base map. Make sure to calibrate your wideband and TPS and save a copy of your map before starting the car.
Tuning Factory Inc. is offline   Reply With Quote
Stand alone engine management options jetfan8178 Normally Aspirated Powertrain 3 03-26-2002 01:19 PM
AEM Stand Alone Moe33 General Community 11 02-26-2002 12:06 PM
Stand alone scan tools LVSUBARU Normally Aspirated with bolt-on Forced Induction Powertrain 12 02-15-2002 10:31 PM
For those looking for stand alone engine management... DanMan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 02-02-2002 02:30 AM
Unichip offered as a stand alone unit? Diz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-30-2001 11:12 AM
