Welcome to the North American Subaru Impreza Owners Club Thursday October 27, 2016
Old 10-15-2001, 11:32 PM   #1
Member#: 10343
2000 Impreza RS 4 dr
Blue Ridge
Question Engine check light coming/going
Had TC II chip, Stromung with mid-pipe, Ganz CAI.
Added Borla header with heat wrap. Runs fine for
over a week(on 87 Octane reg. gas). Filled with
91 Octane premium fuel in the morning, noticed
check light on in the afternoon. Sat for the week end. Started car Monday morning,
no light, after fully warmed up driving on freeway,
light on again. Parked the car all day. Started to come home, no light and when it warms up, light on again. Next when tank goes empty, trying
with reg. fuel again. Car acts normal.
What gives? Any ideas?
subnewbie is offline   Reply With Quote
Old 10-16-2001, 12:44 AM   #2
Member#: 9213
2000 RS
Did you have your 02 sensor replaced? There was a recall on it. Check with your dealership, and see if your VIN number is one that was recalled.
Jademonkey is offline   Reply With Quote
Old 10-16-2001, 02:01 AM   #3
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Mine does that when the knock sensor comes loose (long story)
It will loosen up and lose it's ground connection setting off the CE light, i tighten it up reset the ECU and it's fine.
The O2 sensor is another good place to look like Jademonkey said...
Old 10-16-2001, 03:13 PM   #4
Member#: 9099
2000 Impreza 2.5RS
I had the same problem when I switched from 87 to 91 octane. When I took it to the dealer the code pulled was for the cat, apparently it thought it was running inefficiently and decided to throw a CEL. So it is not a big deal. I reccommend either getting used to looking at your CEL or get a band-aid to cover it up.
Sweder21 is offline   Reply With Quote
Old 10-16-2001, 04:04 PM   #5
Member#: 251
1998 Impreza 2.5 RS
Another possibility, check the plug between the ECU and 02 sensors. I had all the service guys at my dealership stumped. Both 02 sensors read zero and kept throwing codes and the CEL light. After 4 new sensors, new cats, new headers, etc, they finally checked the plugs and found that they were badly corroded. After cleaning them off, no CEL light in over 1000mi.
Good Luck,
cakagan is offline   Reply With Quote
Engine check light & Cruise light on Plasteredcat Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 05-19-2004 11:55 AM
Engine check light jskho Bay Area Impreza Club Forum -- BAIC 2 09-21-2003 10:45 PM
Engine Check Light NiTRoN Legacy Forum 5 12-11-2002 10:14 AM
Engine check lights skullguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-31-2002 04:36 PM
engine check light STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-27-2001 05:40 PM
