Old 06-17-2006, 10:07 PM   #1
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Question Stage 2 with 3/16 mod works for me - why?
Kinda long - sorry in advance...
So I've been running my Cobb Stage 2 for a couple years now. I purchased it whn it was just the AccessECU. Initially when I got it, I couldn't hit the targeted boost with the stock solenoid. Since I had the 3/16 coupler laying around, I figured I'd try it - knowing that Cobb was sending out a special coupler to get people to targeted boost. Ever since that day, I've been hitting the targeted boost in all gears with minimal spiking. Fourth and fifth gear pulls are right between 15.8 - 16.1 psi (verified each time with Accessport's live boost) when the pedal is floored. If it spikes, it goes to 16.1 and then drops back down to about 15.8 and stays there.
So next week, I'm due for my Protune with Jarrad from PDX. I thought maybe I should go back to the stock coupler maybe? Today I switch back to the stock piece and reflashed to ECU. I did at least ten runs and I could only get 8.9 psi. Each time the pedal floored and it just wouldn't go any higher. So I'm puzzled because shouldn't the stock coupler allow a bit more boost than 8.9 psi? And why is the 3/16 coupler allowing me to reach the targeted boost that Cobb advertises? I mean it seems that even if I give the time for the ECU to learn with the stock piece, that it shouldn't be almost 50% below where it should be at.
I was thinking if maybe it could be my t-valve/connector? I don't recall if I switche that out or not. Could an aftermarket t-connector cause the stock coupler to not reach higher boost? And if that's the case, does it make sense that it allows the 3/16 to do so?
Just to make sure. Here's a pic of the stock coupler piece and the 3/16 coupler I have (stock piece on left):
And here's the t-connector (I don't know if this is the stock piece or the aftermarket one I purchased):
Hank3 is offline   Reply With Quote
Old 06-17-2006, 10:46 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
You are probly missing the restrictor pill in the vacume hose from turbo nipple before the T, and the 3/16 conector allows your boost controler to bleed off enough air to allow 15.8 PSi. Instead of just wastegate pressure of about 8 PSi.
wrxdrvr is offline   Reply With Quote
Old 06-18-2006, 05:30 PM   #3
Hank3
Member#: 16157
'03 Mazda P5 <><
Just checked the setup and the restrictor pill is in the vacuum hose. However, while disconnecting the hose from the t-valve, the t-valve cracks in pieces (I'm guessing due to the heat). Is the stock t-valve 5/32? And any other theories as to my ghetto setup?
Old 06-18-2006, 05:48 PM   #4
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Maybe wastegate adjustment is out, Need more preload? Wastegate opens at too low pressure.? That's another reason 3/16 works as it lets off more of the pressure than the stock connector.?
Old 06-18-2006, 05:53 PM   #5
Hank3
Member#: 16157
'03 Mazda P5 <><
hmmm...maybe. In the meantime, I need to buy a new t-connector. I have a 3/16 one but I'm assuming that's not the stock size. Any ideas on what size it is?
Old 08-10-2006, 06:28 AM   #6
rex.effect
Member#: 99745
2013 C-Max Hybrid
Titanium White TriCoat
did you ever get this worked out? what happened?
rex.effect is offline   Reply With Quote
Will an STI stage 2 map work for me? roloc31 Built Motor Discussion 3 11-20-2008 06:06 PM
3/16 mod on Prodrive stage 2 ronf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 01-28-2004 11:51 AM
Is 3/16 mod good or bad idea with ecutek? rtd2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-02-2003 05:57 PM
3/16 mod with MBC?? Rallyman5 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-05-2002 06:12 PM
3/16 mod question...3/16 hose instead of restrictor? Camperguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-04-2002 04:28 PM
