Old 06-17-2006, 10:57 PM   #1
mapleleaf
Member#: 103399
2009 Stripped STI
Dirty White
Default Stage 3 VF39 Experts
I'm swapping my current VF for another newer VF39. It has the stock restrictor pill and factory vacuum lines.
Do I need to drill the pill in the stock vacuum line, or does this only apply when you are using your line and pill from the stock TD04.
The Cobb map notes don't seem to specify a difference between the stock turbo pill or a VF39 from a STI.
mapleleaf is offline   Reply With Quote
Old 06-18-2006, 12:31 AM   #2
UndertoW101
Member#: 100587
2012 WRX 5D Ltd.
I would just make sure it's the correct size that cobb notes
UndertoW101 is offline   Reply With Quote
Old 06-18-2006, 01:45 AM   #3
black06wagon
Member#: 97270
yeah, it should be fine but why not shell three bucks for the drill bit and check it
black06wagon is offline   Reply With Quote
flashing to stage 3 with vf39 dumpstercrusher AccessPort 2 10-09-2007 11:39 PM
Cobb Stage 3 vf39 Now ProTune Question zipossible Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 05-02-2007 09:42 AM
Stage 3 part out. VF39, STI TMIC, SPT Catback tankerWRX MWSOC Private Classifieds 7 02-22-2007 11:01 PM
restrictor pill question.. 06 WRX MT VF39 Stage 3 xmystikx AccessPort 9 01-29-2007 06:29 AM
06 wrx vf39 cobb stage 3 numbers dodiox Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 02-22-2006 02:27 PM
