Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 06-18-2006, 02:04 AM   #1
2-quick4u
Member#: 88624
Default Launch Control & Flat shifting acts like a rev limiter
I have launch control set up and working just fine. But when I turn on flat shifting in motion, my launch control setting acts like a rev limiter all the time. Doesn’t matter if the clutch is in or out.
I did not expect not being able to drive the tack beyond the launch control rpm setting when driving normally.
I expected the flat shifting/launch control rpm setting to kick in only when the clutch is pressed in motion
Is this normal not to be able to rev past the launch control rpm setting when turning on the flat shifting in motion setting?
Does it have anything to do with I/O settings low priority vs. high priority?
2-quick4u is offline   Reply With Quote
Old 06-19-2006, 10:19 AM   #2
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
The flat foot shift will not work on a Subaru unless you have the Element Tuning Accessory Wiring Harness. It will over rev during shifts otherwise.
Give us a call and we can set you up with one.
Thanks,
Phil
240.246.0302
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 07-14-2006, 03:52 PM   #3
thejean
Member#: 17763
How much extra is the Element Tuning accessory wiring harness?
thejean is offline   Reply With Quote
Old 07-14-2006, 07:04 PM   #4
Element Tuning
Member#: 54918
673 WHP Element
It's $59.
Thanks,
Phil
Launch Control and flat foot shifting explained BCT182 AccessPort 36 05-30-2015 12:29 PM
Launch control & Flat Foot Shifting issue 2009 WRX 2407WRX AccessPort 4 06-17-2009 02:38 PM
08 launch control and flat foot shifting 08Pearlhatch AccessPort 1 07-09-2008 08:13 PM
Accessport Launch Control and Flat Foot Shifting powerlabs AccessPort 31 09-15-2007 03:33 PM
Launch control and flat shift...what do you think? Onederer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 10-23-2002 06:40 PM
