Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 07-15-2006, 01:35 AM   #1
THE-95-STi
Member#: 113734
2oo3 Vdub 1.8T
Subaruless(MAIC4LIFE)
Default Help me PhiL
I know, but it's the weekend and I doubt he's answering his work phone. Worth a try to get the car running
So I got my Hydra reflashed and updated, talked to James and he "said" he spoke with you and that it was ok to use the original map for the old software , well when I reloaded the map(or tried to) it told me it was not the correct software and that using it could cause coil damage, so I left every thing still on the car because I hooked into the boost vac line, plus I was sweating my butt off outside. So if you happened to see this, this weekend and if your not to terribly busy, would you mind shooting a base map to me for the updated software. I'll go ahead and email you back the current map, just in case, I just seem to have no luck with this thing, from the wiring Harness to the B/vac Nipple to the Maps
Scott
[email protected]
Mods:
Turbo XS
TBE(high flow CAT)
FMIC
Manuel boost controller
Type H BOV
K&N big cone filter
Perrin Short ram
THE-95-STi is offline   Reply With Quote
Old 07-16-2006, 10:39 AM   #2
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Scott,
You need to download the lastest 2.17 software at www.hydraems.com and should not download with the old software since you have changed to a newer flash. The map is ok but the software is not.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 07-16-2006, 03:33 PM   #3
THE-95-STi
Member#: 113734
2oo3 Vdub 1.8T
Thank you once again
Aaargh! Help me Neek! Help me Tom Cruise! banman Off-Topic 16 09-08-2006 01:50 AM
Help Me, Help Me, Help Me! againstdan Newbies & FAQs 9 11-11-2005 10:26 PM
I need to get a sound clip from ATHF... help me Obi W... I mean help me OT! Asinine Off-Topic 7 03-03-2005 12:33 PM
Help Me! Help Me Please! wrxxxappeal Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-10-2003 11:14 AM
Help me/Help YOu/Help ME MichiganRS General Forum Archive 7 12-15-2000 08:54 AM
