Old 06-18-2006, 08:13 AM   #1
Bullitt 2496
Member#: 53724
2013 Subaru BRZ LS2
Default 06 VF39 Map Cel Problem
I just installed the VF39 setup in my 06 WRX. I'm running the 93 octane map.
The only mod I have besides what they list is that I swapped in an sti 6-speed gearbox.
If I go wide open in 6th gear, the car will overboost to almost 20 psi and I'll get the cel P0244 (wastegate performance).
Every other gear seems fine and I get about 18.5 psi.
I verified the restrictor pill with a #57 bit, which runs through the hole with a little rubbing, so I assume its the right size.
Could my gearing be throwing off the tune and causing too much boost?
My other mods are:
Invidia V3 DP
Fujitsubo RM01A Cat Back
STi Top Mount
Bullitt 2496 is offline   Reply With Quote
Old 06-19-2006, 04:02 PM   #2
th3w0rm
Member#: 98962
2006 OBP WRX
42Autosports tuned vf39
I've gotten the P0244 cell a couple of times as well (5spd). I talked to the guys at cobb and they say that may be fixed in the new version of the maps they release? I hope that's the case, it's not a pleasant feeling with that thing hiccups under boost.
th3w0rm is offline   Reply With Quote
Old 06-19-2006, 11:20 PM   #3
F-H
Member#: 79775
Try the PDXTuning maps. There have been several guys post up their results with the VF39 on the 06 WRX
F-H is offline   Reply With Quote
Old 06-19-2006, 11:32 PM   #4
ADR 04STi
Member#: 51918
2015 Audi S3
Daytona Gray
LWG Map? If not just keep your foot out of it. Or spend some $ on some PDX maps like me.. .and have a killer running subie.There is hidden HP/TQ still, running less boost.
ADR 04STi is offline   Reply With Quote
Old 06-20-2006, 12:08 AM   #5
UndertoW101
Member#: 100587
2012 WRX 5D Ltd.
Try adjusting your wastegate arm
UndertoW101 is offline   Reply With Quote
Old 07-08-2006, 06:48 PM   #6
scooby24
Member#: 56414
2004 Forester XT 5MT
Bump.
I'm experiencing this now too. If I open it up in 4th It'll hit right at 18 and then it'll creep just ever so slightly and hit boost cut.
I had bought the restrictor pill from a VF39 when I installed everything but I just verified it's a .043 sized hole so that's not the issue.
Has Cobb released (unofficially) a LWG map for the VF39?
I have the invidia V3 DP and G200 cat-back.
scooby24 is offline   Reply With Quote
Old 07-08-2006, 07:53 PM   #7
hippy
Member#: 36528
2002 Impreza Wrx
I don't think a map will change anything unless it somehow removes the boost cut. Ya might wanna do a search for boost creep.
peace
Old 07-08-2006, 07:58 PM   #8
scooby24
Member#: 56414
peace
Don't worry I'm very familiar with it...had to port my old STi...but target boost is supposed to be around 16.5 so a LWG map should help me hit that target better so if it does jump up a hair it won't hit the boost cut.
Old 07-09-2006, 03:22 AM   #9
UndertoW101
Member#: 100587
2012 WRX 5D Ltd.
Old 07-09-2006, 11:28 AM   #10
scooby24
Member#: 56414
VF39 is not adjustable.
Old 07-09-2006, 12:35 PM   #11
CynicX
Member#: 48199
06 WRX
Instead of waiting for a map have it protuned...a tuner should be able to work the bugs out of it. I hate to call this a solution but I cant imagine designing an OTS map for a car thats has a different turbo and exhaust and expect it to work on 100% of the cars.
CynicX is offline   Reply With Quote
Old 07-09-2006, 01:04 PM   #12
scooby24
Member#: 56414
I've got the street tuner software. Waiting to see if I can just get the VF39 base map converted to .stb so I can just do it myself if it's really THAT hard to modify the OTS and make a LWG and HWG map the same way they did it for the STi.
vf39 map problems breezeby AccessPort 2 01-28-2008 01:45 PM
Anyone have a 06+wrx TD05-16G (regular 16G) of VF39 map? Davenow UTEC 2 06-10-2007 01:10 PM
06 IHI vf39 map with VF34 turbo 06WRXTR AccessPort 1 12-25-2006 03:32 PM
Got a Protuned 06 WRX VF39 map? scooby24 AccessPort 3 08-11-2006 11:54 AM
new cobb vf39 maps for 06 meat_WRX AccessPort 10 05-17-2006 07:29 PM
