Old 06-18-2006, 02:16 PM   #1
random1
Member#: 105374
2005 Sti
Default 2006 wrx cobb vf39 protuned results
Hey Guys,
I'll post up the dyno charts soon but here's the results.
Baseline (cobb's map):
peak HP 259
peak Tq 250
Protuned (by Chris@ XXTuning)
peak HP 265
peak Tq 295
There's an interesting story that goes with my car's tune. Apparently, Cobb's ots vf39 map was running considerably (almost dangerously) lean on my car and Chris had to richen up the afr. This was a surprise to me since I thought Cobb maps were pig rich.
The bad news is that as good as the 06 injectors are (nobody knows exactly how much they flow), the fuel flow was maxed out at about 5000 rpm. Assuming I install a better fuel pump and maybe better injectors I could really optimize the vf39. Right now my boost is safely limited to about 17-18 psi but I'll probably make this change sometime in the future.
The good news is that hp went up by about 25% throughout the entire powerband even though peak hp is up by only 6hp. Peak Tq went up by 45lb-ft and this difference is pretty much shown throughout the whole powerband too. The power delivery is smoooooooooth now too, it almost feels like a NA car.
My opinion is that it doesn't "feel" a whole lot faster than when my car was running on cobb's stage 2 map but I'm sure it has to do with the improved power delivery and I'm not getting the kick in the pants feel when boost comes on. It's also 90 degrees outside so maybe that's affecting the car's power? Let me know what you guys think.
My mods are:
STI tmic
VF39 (wrapped with insulation)
Helix DP
STI axle back
Cheers!
Joe
random1 is offline   Reply With Quote
Old 06-18-2006, 02:34 PM   #2
Sypher
Member#: 106366
2006 WRX
=\ this is strange, it seems everyone is getting drasticly different results
Sypher is offline   Reply With Quote
Old 06-18-2006, 02:35 PM   #3
Sypher
Member#: 106366
2006 WRX
260whp as a baseline seems pretty low =\
Old 06-18-2006, 02:41 PM   #4
kn0bby8
Member#: 97644
2006 WRX
All dynos are diferent Blah Blah Blah
What does a stage 2 STI run on that dyno? What about a protuned stage 2 STI?
With a protune and a VF39 shouldn't you be around 300whp similar to a protuned stage 2 STI.
kn0bby8 is offline   Reply With Quote
Old 06-18-2006, 02:46 PM   #5
Turbineguy
Member#: 99889
'06 STI
No AVCS on the WRX if I recall correctly. This could also account for some difference vs. an STI.
Turbineguy is offline   Reply With Quote
Old 06-18-2006, 02:50 PM   #6
alltracin
Member#: 100265
1999 powered '90
Miata
wrong. we have that too.
alltracin is offline   Reply With Quote
Old 06-18-2006, 04:42 PM   #7
Sypher
Member#: 106366
2006 WRX
=\ the injectors flow MORE then the STi's it has been tested and people DO know 100%. Everyones car takes to mods differently, and I wouldnt even bother boosting more thn 18psi on a VF39.
Old 06-18-2006, 04:54 PM   #8
random1
Member#: 105374
2005 Sti
Someone with a stage 2 sti had protune done at xxtuning recently too. 287 whp & 321 tq.
Yeah, I thought the 06 wrx injectors flow more too, but apparently they couldn't flow enough to support more than 18psi of boost. I don't know of any other 06's that have done a dyno tune to compare my results with, but at the same time I did ask for a safe tune. So it seems like I should be able to come pretty close to 290-300whp if I were to upgrade my fuel pump at the least.
Old 06-18-2006, 05:24 PM   #9
devil doc
Member#: 107279
06 vf39 wrx
black
can u post the before and after dyno sheet so we can see the whole delivery , thanks
devil doc is offline   Reply With Quote
Old 06-18-2006, 06:04 PM   #10
Sypher
Member#: 106366
2006 WRX
i was pretty sure th vf-39 runs out of breath anywhere past 18psi on a 2.5 block, after that your just blowing hot air =\. And I still dont get this thing wtih the injectors, theyve been flow tested, and no one else seems to be running that lean, maybe youve got an injector problem?
Old 06-18-2006, 06:15 PM   #11
devil doc
Member#: 107279
06 vf39 wrx
black
he`s also using the sti intercooler which has a considerable presure drop ,however it doesnt seem bad
Old 06-18-2006, 06:26 PM   #12
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
07 STI 6-Speed Goodness!
Can the 06 injectors be modded just like the previous years?
ScoobyNubieToo! is offline   Reply With Quote
Old 06-19-2006, 02:23 AM   #13
Sypher
Member#: 106366
2006 WRX
I dont see the point in that =\. Any way I just noticed something, your on a STi axleback, so your midpipe what is it? 3inch? or stock? Like from yoru downpipe to the axleback what size are you running? Also your TQ figures on your baseline, seem pretty low as well. What do stock Sti's dyno on the dyno you used? And you dont feel much of a difference except its smoother, well thats because of the TQ, but still it should pull hard now dude compared to stage 2, I mean its a pretty big jump lol. From previous posts thats like going from a 13.5 car to a 12.6 car.
Old 06-19-2006, 02:28 AM   #14
Sypher
Member#: 106366
2006 WRX
And you talk about changing your fuel pump right? How is your fuel pressure when your accelerating at 100% throttle hitting target boost? Also dude with only 17-18 PSI of boost, I dont understand how your injectors are crapping out. Hell Stock STi injectors are Smaller then yours and there able to boost to 19psi comfortably on VF-39's. Man these subarus are weird, its like with one it makes gobs of power and pulls hard. Another with the same exact mods may be ALOT slower. tuning seems to be a major factor with these cars, also maybe the break in? Idk. It doesnt matter at all but do you have a TR or a WRX Base/Limited? And what was your build date?(if you can find that out)
Old 06-19-2006, 06:22 PM   #15
ucbsti
Member#: 88105
2005 STi
CGM, 2006 GG IX
No, a protuned STi should almost always dyno higher than a 05 wrx with STi tmic/turbo, since the STi has better flowing heads
ucbsti is offline   Reply With Quote
Old 06-19-2006, 08:20 PM   #16
SouthSideTT
Member#: 46224
I think you mean 06 WRX. And is it true that the heads on the STI are better than the heads on other 2.5L's?
SouthSideTT is offline   Reply With Quote
Old 06-19-2006, 08:55 PM   #17
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Stock STi puts down 250-255whp at XX-tuning dyno according to Tony.
Old 06-19-2006, 10:04 PM   #18
06hwrx
Member#: 108401
2007 WRX
i dont know, but your tq seems kinda low though on the baseline. what kind of what kind of rear exhaust pipe/resonator do you have?
with the protune should be somewhere in the 280's at least. i will be getting my protuned soon by MZM and i will post the results soon, i hope mines isnt that low.Or it could be the dyno reads low.
06hwrx is offline   Reply With Quote
Old 06-19-2006, 11:07 PM   #19
jus2quik
Member#: 111237
2006 WRX Wagon
Mona Vie distributer
I just recently had my 06 tuned and got 230awhp/297awtq on the stock turbo with a turbos xs DP,Cobb catback,Ebay TMIC and Ecutek tune,my torque number is nice and peaks at 3600rpm,do you feel the v39 put you into the horsepower range you are in at close to 260 or should it give more?Thinking of throwing a v39 on and getting it re-tuned,I would like to shoot for 260-275 range
jus2quik is offline   Reply With Quote
Old 06-20-2006, 12:03 AM   #20
Yoo Shin
Member#: 87327
2010 12 parsec Evo X
I still kill threads
There's several folks down here in Texas that are running the Cobb OTS map and the VF39/STI TMIC combo boosting right between 18 and 19 psi while running rich in 90 degree weather. Perhaps our humidity is a factor.
Subscribed-
Yoo Shin is offline   Reply With Quote
Old 06-20-2006, 12:53 AM   #21
Sypher
Member#: 106366
2006 WRX
=\ *shrugs* probably
Old 06-24-2006, 02:15 AM   #22
Sypher
Member#: 106366
2006 WRX
not to bring up a dead thread but holy god 297wtq on a stock turbo o_O ****ing christ man thats alot. with a vf39 I still would think youde get 280 at the wheels with a "protune" the TQ with your car shouldnt change or you may gain about 20.
Old 06-24-2006, 10:47 AM   #23
Blackpantherwrx
Member#: 70855
Air Spencer... Squash.
Upgrade the fuel pump
Blackpantherwrx is offline   Reply With Quote
Old 09-07-2006, 05:37 PM   #24
Yoo Shin
Member#: 87327
Do you have a dyno graph you could post?
Old 09-07-2006, 06:41 PM   #25
kaane
Member#: 74006
2005 9-2x
something isn't right on your car. You should not be out of injectors on a vf39. I would have it checked out top to bottom.
kaane is offline   Reply With Quote
My "rogue" vf39 protune results blacktrail Proven Power Bragging 54 03-07-2010 07:57 PM
Florida 2006 WRX COBB VF39 thomtheviking Private Vehicle 'For Sale' Classifieds 1 12-31-2007 05:12 PM
06 WRX VF39 Protune results from Jorge sluflyer06 Proven Power Bragging 31 06-19-2007 10:17 PM
05 STi VF39 Protuned Results sfe Proven Power Bragging 10 02-19-2007 04:04 PM
Cobb AP Protune results STi Crazy Proven Power Bragging 9 02-22-2006 05:08 PM
