Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 06-18-2006, 04:05 PM   #1
o2sys
Member#: 43842
200? WRX STI
Default Went STG 2 Base map, now i get AIRBAG light
I was temporarly driving with STG 1 Base with STG 2 real time map. Car was runnig good. After reading the map notes and COBB recommending to run STG 2 BASE i did so. Everything runs fine, hits target boost. But as im driving the airbag light comes on on the cluster....
It doesnt go away unless i shut the car off and re-start it. Then it comes back on again. Sometimes after couple minutes of driving or something right away....what could it be???
thank you for the help
o2sys is offline   Reply With Quote
Old 06-18-2006, 04:15 PM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
There is something wrong with your air bag system, most likely unrelated to your Accessport flash. Get it tested at the dealership
Old 06-18-2006, 04:22 PM   #3
Freon
Member#: 88322
2009 BMW 135i
^^^ +1. Coincidence. If you really think it is your AP, unmarry, see if you still get it, then reflash again.
Freon is offline   Reply With Quote
Old 06-20-2006, 10:30 PM   #4
NC06TR
Member#: 102601
2006 WRX TR
Crystal Gray
Mine did that last week....if your horn doesn't work, then something is loose in the steering column. If that's not it...try looking at the sensor connectors under the driver's seat and passenger seat. Sometimes they come loose. That's what happened to mine...easiest fix ever. IF that's not it...go to the dealership ASAP.
NC06TR is offline   Reply With Quote
Bullwinkle stg 2 base logs BriGuy375 Open Source Reflashes 1 03-05-2009 03:54 PM
XTM map upgrade from cobb stage 2 base map?? hella_sti AccessPort 0 03-26-2008 10:36 AM
Just went Stg 2, now flashing CEL richde Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 12-03-2005 10:38 AM
Loaded TXS Stage 2 base map, now what to do? jefersun Engine Management & Tuning 4 07-15-2004 05:08 PM
Stg 2 base map == knocking HARD jpmarotta Engine Management & Tuning 12 04-09-2003 01:49 PM
