Old 10-16-2001, 02:01 AM   #1
akcel
Member#: 10268
gc8 I ride ride 24s
with the top down low.
Default wrc intake manifold for fmic
i know it has had to be covered before...and i have been searching i've used "backwards intake manifold" "backwards intake" "reversed intake manifold" "reversed intake" as search strings....but im still trying for more information.. any other terms i should look up?? or could you guys just post some pics for me? and some info on doing this?
-akcel
akcel is offline   Reply With Quote
Old 10-16-2001, 02:13 AM   #2
Ethan
Member#: 246
www.b-specusa.com
Don't know why they couldn't just take a normal photo...
Ethan is online now   Reply With Quote
Old 10-16-2001, 02:15 AM   #3
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Basically just bolt the manifold on backwards (yes it workd that way) and fabricate some throttle linkages and stuff and find a place to relocate some stuff
Eric
Eric SS is offline   Reply With Quote
Old 10-16-2001, 02:46 AM   #4
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
A/C wouldn't work with the flipped manifold though.
Keiho is offline   Reply With Quote
Old 10-16-2001, 02:55 AM   #5
akcel
Member#: 10268
gc8 I ride ride 24s
yeah i've seen those already...what all would have to be relocated..i see the batery...im takin my a/c out i guess...ummm looks like alternator needs to move over a little?
-akcel
Old 10-16-2001, 02:58 AM   #6
Andrew
Member#: 1170
2005 STi
fuel lines will need to be extended.
Andrew is offline   Reply With Quote
Old 10-16-2001, 06:45 AM   #7
Cacophony
Member#: 213
2004 Mazda RX-8
You can't just "flip it around" unless you don't mind hacking a hole through your hood.
Cacophony is offline   Reply With Quote
Old 10-16-2001, 01:44 PM   #8
akcel
Member#: 10268
gc8 I ride ride 24s
what do u mean? why would you put another hole in the hood?
-akcel
Old 10-16-2001, 02:24 PM   #9
Aphex
Member#: 146
'16 WRX Limited
from everything that I've seen, you can just "flip it around" sure you have to re-route a lot of things, move things and other various projects, but hood clearance isn't an issue I don't believe. somebody correct me with some proof if I'm wrong
eli
Aphex is offline   Reply With Quote
Old 10-16-2001, 02:34 PM   #10
MPREZYA
SCIC
Member#: 85
FYI zerosports has a kit for reversing the intake manifold.
Probably pretty pricey and alot cheaper than trying to hack and chop your self. In fact IMHO Byron is using the same kit .
MPREZYA is offline   Reply With Quote
Old 10-16-2001, 03:08 PM   #11
akcel
Member#: 10268
gc8 I ride ride 24s
where is this zerosports?......www.zerosports.com? or something?
hmmm
-akcel
Old 10-16-2001, 03:24 PM   #12
Cacophony
Member#: 213
2004 Mazda RX-8
I've been told that there are hood clearance issues relating to just flipping the damn thing around.. I could be wrong.
It's utterly, utterly pointless to cut and paste the thing on the other way, unless you really like to torture yourself. Run an adequate turbo and the amount of piping isn't nearly as big a deal as people make it out to be.
Zero Sports can be found at www.zerosports.co.jp
Old 10-16-2001, 03:39 PM   #13
kaos200
Member#: 2692
look at how the throttle body sits, and the clearance to the hood, it wont fit a pipe in there (nevermind the TB itself) the plenum needs to be cut and welded differently
There are more things that yeild higher net power gains, are less work, and don't cost you your A/C...
Why go all out on this if you're not going all the way in everything else in the engine bay?
kaos200 is offline   Reply With Quote
Old 10-16-2001, 04:23 PM   #14
iodine23
Member#: 4071
2001 Impreza 2.5RS
Blue Ridge Pearl
Isn't that the A/C compressor sitting behind the red pipe in the pictures? Or maybe it's a relocated alternator...
iodine23 is offline   Reply With Quote
Old 10-16-2001, 04:44 PM   #15
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
That's the alternator.
Ben
bsquare is offline   Reply With Quote
Old 10-16-2001, 05:00 PM   #16
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Default In those pics..
Battery is missing - probably relocated to the trunk.
Windshield washer fluid bottle is missing - you mean it doesn't rain in sunny California?!?
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 10-16-2001, 05:51 PM   #17
akcel
Member#: 10268
gc8 I ride ride 24s
Default Re: In those pics..
LaterZ!
Darren!!
actually if u look closely...the battery is right where a tmic would be placed
-akcel
Old 10-16-2001, 06:13 PM   #18
Jay_UK
Member#: 296
I find it so funny that Byron reversed the manifold... but didnt design a new radiator or intercooler to minimise the air path.. what a complete waste of time..and purely for looks only.
You can still get the aircon to fit .. if you move the alternator and the aircon pump to one side (requires simple brackets making.. longer belts and a new tensior)
The manifold will fit under the hood when reversed.
Yes, you have to redeisgn the fuel rails, purge system, AIC sysem (depends on MY of engine).
If you are going to this extreme, then fit a new radiator and intercooler that allows the pipe to enter over the top (under the beam).
Ideally it needs to leave the turbo and go under the manifold, past the powersteering pump and to the intercooler, then from the intercooler, up and over the radiator and straight into the reversed manifold... this ensures the shortest and most direct path.
J.
Jay_UK is offline   Reply With Quote
Old 10-16-2001, 06:17 PM   #19
iodine23
Member#: 4071
2001 Impreza 2.5RS
Blue Ridge Pearl
Well you don't have to look that closely for the battery, not too many other components should have two big clunky terminals hanging off the top.
It's good to see he kept the stock horn in there.
Old 10-16-2001, 08:27 PM   #20
SubaFastR
Member#: 5786
JC of UPRD built the manifold after Byron showed him a picture of the zero sports one. It is necasary to cut where the throttle body bolts up to decrease the angle, allowing it to fit under the hood.
Kevin
SubaFastR is offline   Reply With Quote
Old 11-20-2005, 12:12 AM   #21
reedperformance
Member#: 96195
04/1 Impreza STI/RS
Blue/Silver
Subaru Stars found one 4 u
-akcel
go to tsl motorsport you'll see it
reedperformance is offline   Reply With Quote
Old 11-20-2005, 01:49 AM   #22
imp2.5
Member#: 11354
Umm... I think he has probably solved his problem by now
imp2.5 is offline   Reply With Quote
intake manifold and fmic piping color? under0athh51189 Interior & Exterior Modification 45 06-05-2010 10:19 PM
IL:FS Build engine & Customized PERRIN GT35R kit with reverse intake manifold & FMIC DickWRX Engine/Power/Exhaust 57 01-26-2007 09:32 AM
Looking for intake manifold for 00 RS MadMax New England Impreza Club Forum -- NESIC 4 12-16-2004 04:02 PM
reverse intake manifold and fmic OneArmedScissor Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-29-2004 04:14 AM
Intake Manifold for Front Mount IC Tarmac Terror Normally Aspirated Powertrain 9 01-16-2001 10:14 PM
