Old 06-19-2006, 12:05 AM   #1
jkoc
Member#: 105024
Default camber range for Whiteline rear adjustable control arm kit
hey folks,
i couldnt find this info anywhere.. does anyone know how much positive camber adjustability there is on the whiteline adjustable rear control arm kit?
also does this KTA109 version fit the 06 wrx?
thanks
jkoc is offline   Reply With Quote
Old 06-19-2006, 12:45 PM   #2
jkoc
Member#: 105024
bump.. any clues?
Old 06-19-2006, 12:48 PM   #3
Samurai Jack
Member#: 21145
2002 Enemy of Aku
According to Whiteline's spec sheets, the KTA109 is NOT listed for the 06 WRX sedan. Just the KTA107, which only has toe adjustment
Samurai Jack is offline   Reply With Quote
Old 06-19-2006, 12:52 PM   #4
jkoc
Member#: 105024
damn
that sucks. so i guess i 'll have to stick with camber bolts. hopefully they wont slip
Old 06-19-2006, 04:05 PM   #5
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
KTA109 is listed under Impreza WRX GD2 (MY03-on). This kit should fit your WRX. No real changes to the WRX rear suspension, unlike the STi track change a couple of years ago.
Regarding camber, you can get plenty of camber and toe adjustment. how much exactly I can tell you but more than you'll ever physically need.
Arnie is offline   Reply With Quote
Old 06-19-2006, 08:17 PM   #6
kennyvb
Member#: 70234
MY86 BMW E30 325
SCIC/NWIC tranplant (-_-)
you want to get camber plates if you want to do any "substantial" camber changes. you can also get another pair of stock camber bolts (that come in the front) and drill out your strut hole and knuckle. for adjustable lateral links, you generally don't want to extend the axles too far which is a consequence dialing in more negative camber. i've read that 1/8" in arm length is about a 1/3 degree change in camber.
kennyvb is offline   Reply With Quote
Old 06-20-2006, 10:50 AM   #7
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Saw that in the spec sheets but also saw that the KTA109 wasn't listed for the '06 WRX sedan. Thought perhaps there was some change that would preclude the KTA109 from fitting on the '06 WRX sedan.
Perhaps the best course of action might be to e-mail Whiteline and find out if the lack of listing of the KTA109 was a clerical error or some other reason.
Old 06-21-2006, 03:43 PM   #8
Samurai Jack
Member#: 21145
2002 Enemy of Aku
^^^ and the answer is:
Originally Posted by Wojtek
The MY06 fact sheet has not been updated with the latest information. KTA108 and KTA109 do fit MY06 WRX wagon and sedan respectively, as is listed in the catalogue.
Thanks,
Wojtek.
__________________
Whiteline Flatout
FS NoCAL Whiteline Rear Adjustable Control Arms Toe & Camber Sedan & Wagon ciajeff Suspension/Brakes/Handling 4 05-19-2008 10:16 PM
FS: Whiteline fully adjustable control arms.. bsikora Suspension/Brakes/Handling 6 01-08-2008 12:38 PM
FS: Whiteline fully adjustable Control arms.... bsikora TXIC Private Classifieds 8 01-07-2008 01:31 PM
FS: Whiteline Rear Adj. Control Arms for '02+ WRX jpmarotta Private 'For Sale' Classifieds 13 09-14-2004 10:21 PM
whiteline rear adjustable control amrs on the STi del105 Brakes, Steering & Suspension 3 03-11-2004 01:38 AM
