Old 11-02-2000, 08:58 PM   #1
Kruf
Member#: 2612
Question New Owner needs advice!
Guys, I'm having a bit of a dilemma. My car is acting up and I am not sure where to start. I am having a stumbling? hesitation?
missing? problem under moderate acceleration.
I changed out the spark plugs (which helped
with the power) but it didn't help this wierd
lagging? surging? thing. This doesn't seem to happen at full throttle but is very noticeable at anywhere from cruise to 2/3 throttle. IF you have any ideas, I'd appreciate it if you emailed me. I was a mechanic, so I will be familiar with technical terms, But I just am not familiar with this platform yet. (anyone have an rx7 that is missing, I can help you there!). Thanks for any help.
Kruf is offline   Reply With Quote
Old 11-02-2000, 11:09 PM   #2
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Exclamation
Take a look at Gary's "Hesitation" fix and see if it describes your car's symptoms. If so, You are not alone!!
http://home.earthlink.net/~hobiegary/hesitation.htm
Glenn
nuburu2 is offline   Reply With Quote
Old 11-03-2000, 03:37 PM   #3
gumball
Member#: 1209
Post
Yeah, I second Glenn's post. I had the hesitation problem on my '97 2.5. The Subaru TSB fingers the 2.2s for some makes as well. The easiest way to find out if that's theproblem is to do an ECU reset. Either disconnect the negative battery terminal for 30 mins, or, if you hate resetting your radio, pull-out the #2 Single Bus Fuse (or something like that) in the front engine compartment fuse box, probably give the flash memory a 20-30 mins to clear.
On-restart, prime the fuel pump a couple times by turning ignition all the way, back and forth w/o starting. Then start & run engine w/o touching the gas until it reaches operating temp. Then shut-down. Start it up again, run it, and see if the hesitation is gone. If it is, then you've got the hesitation problem that Gary describes, and the reset just cleared the ignition timing retard thats stuck in your ECU. But it'll be back!
g'luck!
[This message has been edited by gumball (edited November 03, 2000).]
gumball is offline   Reply With Quote
NEW owner needs Advice? Bl3ng2x Newbies & FAQs 2 05-28-2009 08:42 PM
New owner needs advice 05rs'R'us Newbies & FAQs 2 11-06-2008 11:52 PM
New WRX Owner, needs advice Eric-BlackWRX Newbies & FAQs 10 06-24-2005 03:27 PM
New 04 WRX Wagon Owner needs advice. axjms Alaskan Impreza Club Forum -- AKIC 16 09-17-2004 02:39 PM
New GT 2.5 Owner needs advice Kruf Legacy Forum 2 10-09-2000 11:26 AM
Message Board Statistics All times are GMT -4. The time now is 06:52 PM.
