Old 06-19-2006, 07:37 AM   #1
PJC1909
Member#: 50274
2004 WRX Wagon
invisible
Default 91 vs 93 octane base map
So I picked up the StreetTuner and installed it. I figured I'd start with the Stage 2 base map, since I was running the st 2 93 map on the AP.
What are the differences between the 91 octane ST and 93 octane AP base maps?
In the 93 is there less fuel, more timing, more boost or a mix of these?
I am a tuning noob, so any guidance would be helpful. An ST mirror of the AP 93 map is obviously not my endpoint, but I'm just trying to get a vector (direction and magnitude) for changing tuning.
thanks,
pjc
PJC1909 is offline   Reply With Quote
Old 06-19-2006, 11:28 AM   #2
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Pull up the 93 and 91 maps and compare the tables in ST. My copy should be here today, so I'll look too and let you know what I find. I'm guessing a little more fuel, a little more advance on the timing, and maybe just a bit more boost.
06rexwagon is offline   Reply With Quote
Old 06-19-2006, 11:43 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....good luck.....
Old 06-19-2006, 01:00 PM   #4
PJC1909
Member#: 50274
2004 WRX Wagon
invisible
Crap. I'm traveling and forgot the hasp key to open ST. So you can open *.ptb files into StreetTuner?
Also I will compare my AP datalogs to some yet to be acquired ST logs and go from there.
Old 06-19-2006, 01:43 PM   #5
06rexwagon
Member#: 114730
[email protected]
you can't open .ptb files, but cobb has the same maps for ST that they have for the accessport. Go to their webpage and download them from "street tuner downloads"
Old 06-19-2006, 05:33 PM   #6
PJC1909
Member#: 50274
2004 WRX Wagon
invisible
On the ST download page, they only have one stage 2 map that I can see. It says "originally designed for 91 octane." Is there another somewhere?
Old 06-19-2006, 05:56 PM   #7
mowgli
Member#: 57435
Default Same problem
I wonder why Cobb doesn't have the Stage 2 93 base map in st . If your upgrading and have no starting point to were you are with the 93 Which way do you go ?
mowgli is offline   Reply With Quote
Old 06-19-2006, 07:19 PM   #8
jebjkey
Member#: 73884
Chapter/Region: HIIC
16 HyperBlue STi
16 Crystal White STI
The ST maps are starting points for you to tune from. Because of this, only 91 octane maps are provided. I can send my 93 octane map to anyone who wants it. I have an 04 so if you do not have an 04 I can send you a screen shot instead.
jebjkey is offline   Reply With Quote
Old 06-19-2006, 09:52 PM   #9
PJC1909
Member#: 50274
2004 WRX Wagon
invisible
jebjkey,
aha! this gets back to my original question about how 91 and 93 are different. would happily accept your kind offer.
pc
Old 06-20-2006, 08:40 AM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
post the screen shots---ALL OF EM .....use photobucket.com or tinypic.com
Old 06-20-2006, 06:54 PM   #11
jebjkey
Member#: 73884
16 HyperBlue STi
Default screen shot of 93 oct map
Ok, I think I got it now.
04 WRX with the following mods of concern:
Cobb SF short ram
VF30
USDM STI intercooler
walbro 255 lph fuel pump
STI pink injectors
one step colder copper spark plugs
Borla headers
gutted uppipe
Cobb catted TBE
LC-1 wideband
Dynamic advance is 4.94 for all cells
OL/CL delay is 0 for all cells
87 vs 91 vs 93 octane... boon4376 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 07-31-2009 11:16 PM
Stage 2 93 Octane Base Map ajdmenthusiast Open Source Reflashes 1 06-04-2009 07:45 PM
91 vs 93 Octane Ozy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 10-05-2004 04:57 AM
EVO VII dyno run 91 vs 93 octane Vishnu Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 01-10-2003 06:15 PM
TXS Stage 2... 91 vs. 93 octane map andygold Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-19-2002 04:25 AM
