Old 04-09-2001, 09:19 AM   #1
bryanw
Member#: 807
2002 WRX Wagon
Post need help with rear differential protector
Trying to install the Subaru one on my 2000 RS. No luck. The slots on the rear that are supposed to fit over the diff housing bolts won't fit. The slots aren't wide enough. The instructions say to pry back the housing to make it go. But I've pried and pried and it's still not exposing anything small enough.
Should I be loosening those housing bolts first or something? It doesn't say that in the instructions.
bryanw is offline   Reply With Quote
Old 04-09-2001, 09:47 AM   #2
DaveM
Member#: 4503
2012 Imp Sport Ltd
Camellia Red
Post
Yes, you need to loosen the bolts so that protector will slide up. Once you've loosen them, pry the diff away and slide up the protector then re-tighten up the bolts.
DaveM is offline   Reply With Quote
Old 04-10-2001, 12:32 AM   #3
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Post
Yeah, loosen the two bolts going into the end of the diff about 1/2" or so, then slide the protector up in there and pry like mad, pushing up on the protector. It's easier with two people.
CosmoTheCat is offline   Reply With Quote
need help with rear suspension parts dogWagon Brakes, Steering & Suspension 2 06-09-2004 12:27 AM
Exhaust with rear differential protector Alex L Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-07-2003 06:43 AM
Need help with rear strut tower brace on '97 Legacy sedan WAFlowers South East Region Forum 6 03-06-2003 09:49 PM
Need help with rear O2 sensor wiring diagram for 2000 Legacy GT jazzman Normally Aspirated Powertrain 1 04-17-2002 10:36 PM
ATTN: All 93 - 95 Impreza Owners: Need help with rear seat questions! MrP0nch0 Interior & Exterior Modification 29 10-17-2000 10:14 PM
