Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 10-16-2001, 11:58 AM   #1
WRBLUEWAGON
Member#: 10745
2006 VW SUV
Question I get full boost 15.14 psi Peak in first and Sec. Gear???
I have done a search on this and people are saying that they only can boost up to 10 psi in first and second gear. Is something wrong with my car? It drives fine and feels fine. Or is something wrong with there cars. Now this is only peak not constant. (I have a peak display on my boost gauge)
I only have a TT and a TURBO XS BOV. No MBC or Unichip.
Any Help would be great.
Eric
WRBLUEWAGON is offline   Reply With Quote
Old 10-16-2001, 12:03 PM   #2
JenisonWRX
Member#: 6049
02 WRX & 99 RS
Where do you have your gauge tapped too?
JenisonWRX is offline   Reply With Quote
Old 10-16-2001, 12:06 PM   #3
WRBLUEWAGON
Member#: 10745
2006 VW SUV
In between the BOV and Manifold.
Eric
Old 10-16-2001, 03:04 PM   #4
Obscure411
Member#: 5719
2008 Impreza 5-Door
Eric,
Doesn't your gauge read out in kPa? If so, like I mentioned before, you're looking at the wrong unit of measurement.
kPa / 0.14504 = PSI
I think you mentioned that you were getting a max of 1.05 in 1st and 2nd, right?
1.05 / 0.14504 = ~7.23 PSI
Or, about right with everyone else who is seeing 7-10 psi in 1st/2nd gear.
Dude, just get an MBC already :-D
As always, corrections are welcome.
- Andrew
Obscure411 is offline   Reply With Quote
Old 10-16-2001, 03:25 PM   #5
WRBLUEWAGON
Member#: 10745
2006 VW SUV
Your killing me man,,
1.00hkPa=14.7
14.7 psi is = to atmosphric persure
so I got 1.06hkPa
=15.582psi in first gear. +- .20
I checked my old books and called up a few tech's on this one. I'm right but corrections are very well come.
Plus than my car would be really messed up because I boost that in 3rd to 5th.
Blitz on there web site said that it can read up to 2.50kpa = 36.75 psi
so 36.75 divided by 2.50 = 14.7psi
14.7psi times 1.06 hkPa= 15.582psi
That is all at peak, So it might have just touched it for a spit sec.
I will show you tonight.
Eric
Old 10-16-2001, 03:43 PM   #6
Obscure411
Member#: 5719
2008 Impreza 5-Door
Wrong.
2.5 bar = 36.75 psi.
My math was slightly in error before, kpa X 0.14504 = PSI.
But 1 psi = ~6.89 kpa, so it's definitely either being expressed in the wrong unit, or you need new glasses
Old 10-16-2001, 03:58 PM   #7
WRBLUEWAGON
Member#: 10745
2006 VW SUV
Yourrrr Wrrrrogggg!!!!
I done with you. Anyone else have any idea's or corrections.
Please help.
Eric
Old 10-16-2001, 04:17 PM   #8
Obscure411
Member#: 5719
2008 Impreza 5-Door
The only descrepency [sp?] I see is the h in front of kpa...
My metric units are a little rusty, but isn't that hectares, as in 10 to the sixth power?
That would make it 10,600,000 kpa, roughly equivalent to 1,537,424 psi
But, just to prove that I'm right, () here's a conversion chart :
http://www.fife.com/conv.htm
or a simple formula :
http://www.plasticsgroup.com/profess...rsion_factors/
[edit : just wanted to add, 1.06 kpa is actually 0.1537318 psi.]
Old 10-16-2001, 04:22 PM   #9
WRBLUEWAGON
Member#: 10745
2006 VW SUV
Eric
EOM
Old 10-16-2001, 04:53 PM   #10
zoomzoom
Member#: 5384
2002 WRX Wagon
Platinum Silver
Default ???
According to my engineering reference,
1 kPa = 0.145 psi or
1 psi = 6.895 KPa
Therefore, if you are truly reading 1.06 KPa, then you only have 0.154 psi of boost!!!
I suspect there is some confusion over your meter's measuring units. Are you certain the gauge is not reading in "bar" measure instead of KPa?
1 bar = 14.5 psi = 100 KPa
Or maybe your gauge reads 100 X KPa (100 X 1000) or in MPa, mega, or 100000 X Pa (I believe Subaru's gauge reads in MPa)
Either way, our soobs are known to limit boost in first gear - I can't remember if it limits 2nd. Fairly certain someone mentioned only 9 psi of boost max in 1st instead of the advertised 14 psi. Supposedly TurboXs' Unichip removes this limit and up boost a bit.
Hope this helps. Cheers
zoomzoom is offline   Reply With Quote
Old 10-16-2001, 05:02 PM   #11
rkkwan
Member#: 5596
2010 Honda Fit Sport
Stop arguing about the maths. zoomzoom is correct. And I don't know what boost gauge you're talking about, but the Subaru OEM ones read in MPa. Max boost should be just under the .1MPa mark [.1MPa = 100kPa ~ 14.7PSI].
So, WRBLUEWAGON seems to be getting higher boost in all gears, especially 1st. I'll have the dealer check it out. Or perhaps your gauge is incorrect.
-Ray
rkkwan is offline   Reply With Quote
Old 10-16-2001, 05:04 PM   #12
WRBLUEWAGON
Member#: 10745
2006 VW SUV
I just got of the phone with Blitz North America
1.00hkPa = 1 Bar
1 Bar = 14.7
1.00hkPA = 14.7
so 1.06 is what my reading on my Blitz Dual TT DC is = 15.582 psi
1.06hkPa X 14.7psi = 15.582
I get that in first gear as a peak reading.
So my Math is right and the convertion is correct as well.
Now why am I getting more boost in first than other people???
Eric
Old 10-16-2001, 05:09 PM   #13
WRBLUEWAGON
Member#: 10745
2006 VW SUV
Thanks for your help. But I don't want to go to the dealer because I can't see it being a bad thing. I have full boost in first.. That rocks because eveyone else has to have a MBC to get what I have stock.
Old 10-16-2001, 05:18 PM   #14
zyounker
Member#: 9573
2002 Impreza WRX
I was getting the same thing.. It spikes to a little under .1MPa (Subaru Gauge pack) then drops a bit in all gears.. I call it a spike cause 500 RPMS has to be a spike.
I installed a MBC and set it for .1MPa The turbo spools up to .1MPa alot quicker but still drops off in the higher rpms (turbo running our of juice)
Maybe they made changes to later model WRXs? I just bought mine about 1 month ago.
-Zach
zyounker is offline   Reply With Quote
Old 10-16-2001, 05:37 PM   #15
kyledooley
Member#: 1055
2005 No legacy for u
It's a diesel
1.0 Bar
= 1000 mBar (milibars)
= 100 kPa (kilopascals)
= 14.7 psi (pounds per square inch)
= 750.06 mmHg (milimeters of mercury)
= 29.52 inHg (inches of mercury)
1.0 Bar is kind of 1.0 hkPa but that is really not the case because there is no such thing as hecto-kilopascals. It is an error in units. The right way to write it would be 1.0 x 10(2) - i.e. Ten squared kPa.
I don't know html enough to superscript.
It may say hkPa on a gauge, but that just some dumbass calling himself an engineer when he's really the graphic designer that is too stuipid to ask the engineer what the real units are. (Trust me, I work with a couple)
He was using the h (meaning x 100) when you can't really combine metric prefixes that way.
The subaru gauge units of MPa are correct. Those are megapascals 1 Bar = .1 MPa and if I'm not mistaken doesn't the subaru gauge read vacuum and then 0-.1? .
Obscure was wrong- he divided by .145 when he should have multiplied. Everyone else seems to have it straight.
Being Canadian, knowing the metric system appears to be more useful than I once thought.
Kyle
kyledooley is offline   Reply With Quote
Old 10-16-2001, 11:35 PM   #16
amelnikov
Member#: 9827
2002 WRX Wgn 292whp
Alex Performance
Eric
the reading is correct, it is 15.582 psi, but a peak reading is just that, a peak reading. A spike. Are you saying that it's staying at that boost all through the first, or just spikes to 15.8 and then drops to lower boost?
Alex...
amelnikov is offline   Reply With Quote
Old 10-16-2001, 11:48 PM   #17
luxcar101
Banned
Member#: 11142
I didn't know that MENSA had a forum for cars... j/k
What does your BoCon do when your car is not in use? Track satelites? [sp?]
luxcar101 is offline   Reply With Quote
Old 10-17-2001, 11:48 AM   #18
Jon [in CT]
Member#: 2992
02 WRX Sedan
Why does everyone (except zoomzoom) mistakenly believe that 1 bar = 14.7 PSI when, in fact, 1 bar = 14.5 PSI?
Jon [in CT] is offline   Reply With Quote
Old 10-17-2001, 12:00 PM   #19
Greenracer6
Member#: 7962
08 335i TwinTurbo
PSM 02WRX, 97 Dipped CRV
Default PSI
Maybe you should hook up a US psi gauge and see what it says, instead of using a bar or metric boost gauge.
Also, if you want a boost controller so you can run 16psi @ all gears full boost. I took my Apex-i AVC-D off b/c I'm getting a Link
$225 if you want it, retails for $330
Bill
Greenracer6 is offline   Reply With Quote
Old 10-17-2001, 12:03 PM   #20
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
probably because .2 psi is so small it's not worth arguing about. I've always heard 14.7psi, but never bothered to check my books because it doens't really matter.
-C
TypeC is offline   Reply With Quote
Old 10-17-2001, 12:05 PM   #21
WRBLUEWAGON
Member#: 10745
2006 VW SUV
Your right 14.7 = 1bar.
But bar does not show - for vacume. That's what Blitz told me
Old 10-17-2001, 03:25 PM   #22
Jon [in CT]
Member#: 2992
02 WRX Sedan
Wow, you just did it again! 14.5 = 1bar.
Old 10-17-2001, 05:51 PM   #23
solomrus
Member#: 1767
autometer sport comp boost gauge:
-18 = 18 inches of vacuum
+15 = 15 psi of boost.
no conversion. no question.
(just being a smartace)
:monkey:
solomrus is offline   Reply With Quote
STi 7: how to get full boost in 1st and 2nd gears? GDB Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 01-06-2015 08:01 AM
Rattle in first and second gear and neutral... Ultimate Newbies & FAQs 0 06-20-2007 11:16 PM
Should factory boost be only 12 psi in 3rd and 4th gears? ImportVenom Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-02-2003 01:54 PM
couldn't get the abc and clb to get more than 15-16 psi so i gave up datdudedennis Engine Management & Tuning 10 05-18-2003 03:24 AM
Defi Boost Gauge @ 14 PSI Peak? W/O Boost controller... STi_Pete Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-03-2002 10:30 PM
