#1 |
Member#: 90396
NWIC
Vehicle:2005 Legacy 2.5i Brilliant Silver Metallic |
So I've got my base fuel without closed loop set very close to what it should be, in some cases it will get to 15.5, others down to mabe 12 under low low vaccume, but it mostly stays between 13 and 15.
Now I turn on closed loop and it does some pretty wierd stuff, like at idle it wants to run 10.5-11.5, then I'll be driving and it might run 14.5-15.2 or so every now and then, but it really likes to stay around 11.5-13, pretty rich. And every so often it will run WAYYYYY lean between -13inMg and -5inMg, like up in 18-19.9(max for my wideband reader). Why is it doing this? When I turn off closed loop my readings are fine in that range, around 14.7-15.5 no where near 18 or 19. I'm using 2.17 w/ my stock rear O2 sensor (I did try it with my wideband to narrowband output from my wideband sensor and it seemed to work better on the stock one until now). And I know the stock one is reading correctly because I can watch the 1.0 change back and forth from 0 to 1 on the tuning screen depending on lean or rich. One thing I did notice though is only 1 on the left changes from 0 to 1, the one on the right stays a constant 1, I dont know if that has anything to do with anything though. Any help greatly appritiated, as always! Nick
#2 |
Member#: 90396
NWIC
bump?
#3 |
Member#: 54918
Nick,
Since you don't have one of my base maps it's really hard to say as it depends on your "closed loop limit" map and your sensor source settings. Thanks, Phil www.elementtuning.com |
#4 |
Member#: 8512
South East
Vehicle:2002 WRX chassis... stage-infinity.com |
Yeah, I didn't reply because there's a lot more info needed.
#5 |
Member#: 90396
NWIC
Closed loop limit is 3 up to 4000rpms, and from 4800 on is 765.
Any other information needed? |
#6 |
Member#: 8512
South East
What are your CL sensor source settings?
#7 |
Member#: 90396
NWIC
Left U/HEGO on both
#8 |
Member#: 90396
NWIC
Well I guess I dont really need closed loop if the car runs better with out it.
#9 |
Member#: 8512
South East
I don't know how much you know, so don't consider this an insult if you already know this stuff:
* I've never used CL with the OEM rear O2 sensor * It doesn't sound to me like you have a well-tuned fuel map to begin with. Things shouldn't be all over the road. You need to spend a great deal of time working on the off-boost section of the map, with steady throttle and load while adjusting things to 14.5:1 or so. Across all RPMs. * Without a well-tuned base fuel map that is very close to your target, I'd guess the CL system is going nuts trying to figure out what to do, in real-time. * For comparison, the fuel map I've been poking around at for 8 months now on and off, never goes richer than 14.2 and never goes leaner than 14.7 in all vacuum conditions with CL off. |
#10 | |
Member#: 54918
Also if you are running 14.7 feed back that may be too lean for your setup. Many cars I tune fall on there face at 14.7-15.0 and really need to be closer to 14.5 with some even richer. Cars with only minor modifications can run 14.7-15.0 all day long but not many cars running Hydras have minor modifications. Thanks, Phil www.elementtuning.com |
#11 | ||||
Member#: 90396
NWIC
And with an open loop fuel map at 14.5 throughout all rpms, why would you need closed loop to adjust to 14.7 if you could do it yourself? I understand the closed loop system only makes minor changes, but why do you need it if your already at where you want to be? Quote:
I suppose I thought it had more power than it does, and by using my unperfected fuel map in closed loop the system just guesses. Thanks for all the responses and advice, I'll just keep plugging away at it until I'm at that "perfect" time in my fuel map to use closed loop. Nick |
#12 | |
Member#: 54918
I typically run Closed Loop with the WB Target Table on all cars I tune and it's just about seamless. The only time you should see AFRs of 18 or higher is under deceleration where you'll see up to 20.8 which is due to the system cutting fuel as it's not required under deceleration. Please post a screen shot of your fuel map so we can evaluate it. It should look something like this: Thanks, Phil http://www.elementtuning.com |
#13 |
Member#: 56468
NWIC
Vehicle:04 Improved STI Dirty White |
I thought that closed loop fueling had to be within a certain percentage of the the target AFR as well. So if your fuel map is off by more than something like 30% the computer does nothing.
Put another way: the computer will only pull or add a certain percentage of fuel under closed loop with a reference to that particular load site. Is that right Phil? |
#14 |
Member#: 54918
Yes, I think I understand what you are saying. It will add or subtract about 25% per given load cell. This is also somewhat of a built in failsafe in case of sensor failure. You really do not want to give it much more authority.
#15 |
Member#: 56468
NWIC
That's what's great about Phil's maps he's already in that margin of 25%. That's still a lot of fuel variation. I rarely change more that 5-10%, and usually less than 2% of the base PWM value.
#16 |
Member#: 90396
NWIC
Hey, not enabling long term learning is a very good idea, I will try that!
My fuel map is kinda ugly right now, but I suppose I'll post a screen sometime. |
#17 |
Member#: 107569
NWIC
Vehicle:1998 Forester S SRP |
Other than the tuning is your car running well with the hydra... Haven't talked to you in awhile.
#18 | |
Member#: 54918
#19 |
Member#: 10955
NWIC
Vehicle:07, 06,01,93 I have 4 domtuned subys |
I may have missed something....
do you have the wideband and the rear o2 plugged in? I can't even plug in my rear o2 sensor if my wideband is plugged in. If I do the afr's oscillate pretty dramatically regardless of any settings. I talked with Hydra and aparently its a known issue. |
| Thread Tools | |
| Display Modes | |
| Does Hydra have Close Loop Control? | Spec C Wannabe | Other Engine Management | 10 | 04-07-2006 02:51 PM |
| 2005 (2004 possibly?) ECU open/closed loop delay able to be tuned out? | Killian Maynard | Engine Management & Tuning | 19 | 05-05-2005 02:37 PM |
| 04 WRX open loop/closed loop problem -- should I be concerned? | perret318 | Newbies & FAQs | 2 | 05-03-2005 05:38 PM |
| open loop VS closed loop | iloveturbos | Newbies & FAQs | 4 | 11-12-2002 07:33 PM |
| My thoughts for closed-loop to open-loop with link. | Chav | Normally Aspirated with bolt-on Forced Induction Powertrain | 0 | 06-28-2002 02:10 PM |
