Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 06-19-2006, 11:57 PM   #1
InfamousDX
Member#: 25413
Question 1000cc Injector options
I'm looking for 1000cc injectors for JDM STI v7 heads. So far I've only found the UR ones for $550. These just look like peak & hold low impedance injectors from RC Engineering ($99/each there) but with the resistor pack. My questions are...
Do I need the resistor pack for these particular injectors?
Do I need the UR fuel rails to go with these injectors for my previously mentioned application?
Are there any other high flow (850cc+) injector options for Hydra users?
1000cc Flow-Matched Fuel Injector Kit
(Each injector flowed within 1% to the next)
- 1000cc Low-Impedance Fuel Injectors (Set of 4)
- Resistor Pack Wiring Kit and Connectors
Old 06-20-2006, 10:23 AM   #2
InfamousDX
Member#: 25413
RC Engineering top feed 1000cc 2.5ohm low impedance injectors. Phil said the Hydra can def. run these w/o the resistor box.
Does anyone know if the harnesses are plug and play with stock harnesses?
Also, if anyone's fit these, I read that they are tricky to fit right in top feed fuel rails. I'll be using Perrin WRX top feed rails with my setup.
Old 06-20-2006, 10:33 AM   #3
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
We have many customers running the low impedance 1000cc injectors with the Element Hydra EMS including myself. We even has good tuned base maps for them.
The Hydra can run low impedance injectors without the resistor box but as stated you need top feed fuel rails. As far as I know only Ultimate makes a direct fit rail. I modified a set of WRX BDL fuel rails to work with the STI TGVs. If you have a WRX or JDM intake manifold for top feed fuel injectors you are good to go.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Injector Dynamics 1000cc injectors - anyone else try them? erikos North West Impreza Club Forum -- NWIC 17 06-12-2009 01:09 AM
Want to trade perrin 825cc injectors for 1000cc injectors drewwrxrogers Private 'Wanted' Classifieds 1 03-27-2008 04:40 PM
Ultimate Racing 1000cc injectors... wrx21144 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 05-02-2006 10:37 AM
WTB 1000cc injectors oldbluwrx Private 'Wanted' Classifieds 1 02-23-2006 04:07 PM
anybody knowwhere i can get 1000cc injectors ryanpietro Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 12-30-2005 12:05 PM
