Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 06-20-2006, 12:08 AM   #1
rodrigo.diaz3
Member#: 111873
2006 wrx/sti
aspen White
Question About Hydra
Hi im new on this i dont know about this engine management.
Is an aditional ecu like the utec, its plug and play???
I make my research on the net because I own a 2006 sti not USDM(280 hp) and hydra cover my car(JDM AND UK).
I really appreciate your coments.
rodrigo.diaz3 is offline   Reply With Quote
Old 06-20-2006, 01:27 AM   #2
keaniegenie
Member#: 94494
2005 Element 92x
The Hydra is the ONLY stand alone ecu you can get to tune an sti. What I mean is it replaces your stock ecu. No piggy back like the Greddy or Utec. Pretend your car was made to be tuned by the factory, what ecu would it come with? This one.
The only other ecu that is close is the AEM, which doesn't work on drive-by-wire vehicles. If you are looking for a basic em to tune your car, this may not be the best choice since cost is high and you lose obd-II, but if you want the best em money can buy, this is it.
keaniegenie is offline   Reply With Quote
Old 06-20-2006, 08:44 AM   #3
rodrigo.diaz3
Member#: 111873
2006 wrx/sti
aspen White
Ok thanks, where i can buy it.
Old 06-20-2006, 10:21 AM   #4
InfamousDX
Member#: 25413
contact Phil @ www.elementtuning.com
Old 06-20-2006, 09:04 PM   #5
rodrigo.diaz3
Member#: 111873
2006 wrx/sti
aspen White
Wink
Thanks i will try to get the engine mangement for my 2006 Sti (non USDM)
Old 06-21-2006, 08:56 PM   #6
El Gato
Member#: 110648
Chapter/Region: PRSIC
2005 Hydramist 35R82
93oct 479whp 456tq
Well you can also get the MOTEC at twice the price, which is also stand alone I think.
El Gato is offline   Reply With Quote
Old 06-23-2006, 02:46 AM   #7
entropy138
Member#: 87446
2005 STI
3 second start club
Yea motecs are stand alone and an awesome ECU at that... But good luck figuring out a LOT of stuff for yourself as not very many people have put them in subys... or at least the people who have aren't running around on nasioc. I think Crawford/Ispeed has a car or two running them but other then that they're pretty rare.
The hydra is an awesome unit and Phil and the support/legwork that he has done getting these things set up with the wrx/sti is awesome. The base map I got had my car running about as good as it did stock (i had an issue w/ calibrating the wbo2) but once that was resolved I have no complaints. The system is wonderful. When you can go from being tuned for a green w/ 850s and swapping over to a rotated setup with no maf, starting the car up and driving down the road like there was no change... you know you got what you paid for... (note that some minor tweaking was required for in-boost driving but for typical in town and highway driving everything was still spot on... MAP based fueling FTW also popped my tmic off the throttle body one time and was driving around wondering why my car sounded louder and I was only getting 8-9 psi lolololol now that was a HUGE boost leak and the car acted like everything was perfect... well minus the low boost)
entropy138 is offline   Reply With Quote
Old 07-14-2006, 05:46 PM   #8
Sneeky Pete
Member#: 97745
2005 OBXT 5spd red
05 OB Lmited Black
and you lose obd-II
Dont think thats gonna be much of a problem........
Sneeky Pete is offline   Reply With Quote
Hydra install on oldschool? tenchu Other Engine Management 0 06-03-2010 04:37 AM
question about Hydra / OEM o2 sensor.. STI_SLC Other Engine Management 2 06-01-2008 03:55 PM
thinking about hydra nptsubie Other Engine Management 6 08-07-2007 03:59 PM
Important Question About Hydra Knock Threashold diplo12 Other Engine Management 13 07-26-2006 12:57 AM
Thinking about going with a Hydra?? THE-95-STi Other Engine Management 27 07-24-2006 01:26 PM
