Old 10-16-2001, 01:12 PM   #1
Vigorous
Member#: 7087
2002 2.5RS
Arrow What to Clean Wheels/Tires With?
My tires are in desperate need of a cleaning. They are turning the ugly brown. My rims are alright, but I cant get to some of the edges. What products should I use on both?
Vigorous is offline   Reply With Quote
Old 10-16-2001, 06:39 PM   #2
Jazz95
Member#: 4600
Da Ridge
Racer
Try Westley's Bleach White on the tires. It also works well on wheels. If you REALLY want to clean the wheels though, jack the car up and take them off. Makes it soo much easier, you can also scrub the calipers while you are at it.
Jazz95
Jazz95 is offline   Reply With Quote
Old 10-16-2001, 08:30 PM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
2001 2.5 RS/70 Van
02 WRX Rally Stud
Wink
meguiar's wheel tire cleaner...
and westley's beach white was a good suggestion too!! ya gotta have westley's...
j.
www.subiegal.com
Old 10-16-2001, 08:34 PM   #4
jacobhorn
Member#: 5122
1998 Legacy GT LTD
'02 HD Softail Deuce
Arrow
For the ultimate in tire cleaning, try Simple Green. This stuff sprays on as a foam and it will get EVERYTHING off of the tires down to the rubber. This is a great way to make your tires look brand new. A bit of scrubbing is necessary. Good luck!
jacobhorn is offline   Reply With Quote
Old 10-16-2001, 11:00 PM   #5
NotoriousWRX
Member#: 9026
To keep them from turning brown once they are clean, do not use any silicone based product such as Armor All. There are a number of better options.
NotoriousWRX is offline   Reply With Quote
Old 10-16-2001, 11:53 PM   #6
Verist
Member#: 6501
I'd say stay away from the Meguiars check this out
Regan-
Verist is offline   Reply With Quote
Old 10-17-2001, 02:44 AM   #7
gabedude
Member#: 10108
07 STI
25G build in progress
Simple Green works wonders. Then just Armor all the tires.
My $0.02
gabedude is offline   Reply With Quote
Old 10-17-2001, 02:56 PM   #8
Scrapy Doo
Guest
Member#:
simple green works great on tires and the wheels, simple green devours brake dust and grease on tires...
but still dishwashing liquid and hot water works wonders
Old 10-17-2001, 03:20 PM   #9
CosmoTheCat
Member#: 3409
1998 Ram 2500
Green.
Don't know about the rest of those products, but Westley's will keep future brake dust from sticking to the wheels. Just wipe with a dry rag and they're clean again.
CosmoTheCat is offline   Reply With Quote
Old 10-17-2001, 03:22 PM   #10
ChrisDP
Member#: 5879
'02 STX WRX
STS Civic, ITA Integra
Don't Armorall the tires if you want to keep them from turning brown.
ChrisDP is offline   Reply With Quote
Old 10-17-2001, 04:15 PM   #11
NotoriousWRX
Member#: 9026
Not only will Armor All make your tires turn brown, it'll cause major cracking.
Old 10-17-2001, 04:33 PM   #12
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Can i use Westley's with OZ rims. I heard i can't clean them with anything too abrasive because it will ruin the finish. What do you guys think. Thanks.
Soon2Bgreat is offline   Reply With Quote
Old 10-17-2001, 05:49 PM   #13
Vigorous
Member#: 7087
2002 2.5RS
Westley's, where can I get this? And what is the product called: "Westley's Bleach White" ? Man, thats a harsh sounding name.
Simple Green, I've never used this, but have seen it everywhere. Do they make a product specifically for tires and rims? Or is there a product used for everything? Whats it called?
Thanks for all the help.
Old 10-17-2001, 05:58 PM   #14
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Simple Green is just an engine degreaser. But it works good for wheels too.
Keiho is offline   Reply With Quote
Old 10-18-2001, 02:15 AM   #15
CosmoTheCat
Member#: 3409
1998 Ram 2500
Green.
Westley's Bleche White.
You should be able to get it at any auto parts store in the tire cleaner section.
It's gnarly stuff though. Don't get it in any cuts. Don't get it in your eyes.
The directions say to not get it on the wheels. But it also instructs you to put it on dry tires.
We used it at Maaco when I did detailing there eons ago (you'll never forget the smell and feel of the stuff after you get it in cuts on your hands).
At Maaco we had it in a diluted solution of water, in a spray bottle... spray it on, scrub with a wet soft bristled brush, and boom. Good to go.
At home, I make sure the wheels and tires are WET. And I take them off the car. If the wheels aren't wet, or if you let it sit on them for too long, it WILL ETCH the finish of your wheels. I spray it on full strength (you'll see brown stuff running off the rubber as you spray, it's that good), let it sit for 30 seconds or a minute, then wipe it off with a wash mitt. The tires I scrub with a sponge or terrycloth rag. Then rinse and rinse well.
When brake dust builds up again, usually it will wipe right off with a dry cloth.
Again. This is some NASTY stuff and I use it against their directions. Follow my advice at your own risk.
What to clean brushes with? kmook Car Care & Detailing 3 03-29-2009 08:58 PM
Headliner, what to clean it with? eurospek Interior & Exterior Modification 20 08-22-2007 10:20 PM
What to clean the stylus on my phono cartridge with? Dolphin Overton Off-Topic 3 06-12-2007 08:03 PM
What to clean tricot upholstery with? supernootz Interior & Exterior Modification 0 02-06-2007 09:51 PM
What to clean my rims with?! NickWRX Brakes, Steering & Suspension 19 07-04-2002 06:45 PM
Message Board Statistics All times are GMT -4. The time now is 06:43 PM.
