Old 06-20-2006, 02:58 PM   #1
superknowva
Member#: 105964
2009 STI
Red
Default Street Tuner - Wideband
Looked around a bit and didn't see an answer to this so I figured I would post...
What's the best (bang for the buck) wideband setup to buy/use with street tuner as a plugin. I noticed a few drivers listed on cobb's site, but wanted some real world opinions. I'm leaning (no pun intended) toward the LM-1...?
superknowva is offline   Reply With Quote
Old 06-20-2006, 06:04 PM   #2
superknowva
Member#: 105964
2009 STI
Red
nobody has this type of setup? Is there another place I should post?
Old 06-20-2006, 06:31 PM   #3
jebjkey
Member#: 73884
Chapter/Region: HIIC
16 HyperBlue STi
16 Crystal White STI
LC-1 is the cheapest setup for wideband. No gage, just use ST to display the AFR.
jebjkey is offline   Reply With Quote
Old 06-20-2006, 10:20 PM   #4
Christian.
Member#: 87604
The PLX R-500 is phenomenal IMO.
Christian.
Christian. is offline   Reply With Quote
Old 06-20-2006, 11:14 PM   #5
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
The LC-1 connects via serial, correct? How do I connect the LC-1 and the cobb cable for ST at the same time? edit: i see it comes with a usb to serial adapter.
06rexwagon is offline   Reply With Quote
Old 06-21-2006, 04:40 AM   #6
jebjkey
Member#: 73884
16 HyperBlue STi
I have two serial-USB converters so I just plug to two USB connectors into the computer. It is easy to find a USB hub that does not require a power cord if you do have the available USB ports.
Old 06-21-2006, 06:40 PM   #7
superknowva
Member#: 105964
2009 STI
Red
thanks guys!
Old 06-27-2007, 01:13 PM   #8
LittleBlueGT
Member#: 96204
2013 STI GR
Resurrection.
What is a good WB (like the LC-1) that uses USB ports? I always have nothing but problems using adapters. I am getting ST and don't need a separate gauge, the display on the laptop is good enough, and I don't wish to spend mor ethen $200 if I don't have to.
LittleBlueGT is offline   Reply With Quote
Old 06-27-2007, 10:38 PM   #9
dElKwOn
Member#: 71184
2002 ewg'd vf-34'd
GDA AMS Tuned !
Christian.
i second that! i have the r-500 ,simply awesome!its not a air/fuel gauge ...
its an air/fuel computer.don't believe me,look @ the features on the plx website.
dElKwOn is offline   Reply With Quote
aem uego wideband, cobb apv1 , and street tuner WrXtaCy2003 Engine/Power/Exhaust 4 10-31-2007 03:51 PM
FS: Accessport, Street tuner, Downpipe, VF22, Pinks, Wideband, Hawk hps, Suspension.. Sausage Engine/Power/Exhaust 25 04-12-2007 11:51 PM
cobb street tuner self-tuning with wideband + gauge 005sti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 10-07-2005 03:21 PM
Street Tuner/Pro Tuner zuczek Engine Management & Tuning 3 07-15-2005 12:37 PM
street tuner and pro tuner question dippi Engine Management & Tuning 0 09-11-2004 12:13 AM
