Old 06-20-2006, 03:01 PM   #1
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
Default whos got pics on the charcoal canister removal?
kaos200 sent pics out, no one hosted them...anyone have pics or instructions?
alex
EDIT
I want to permanately remove the system
Old 06-20-2006, 03:07 PM   #2
idkew
Member#: 99980
isn't there just 3 obvious bolts?
then you pull off the hoses...
i had to "dislodge it" to install my sways and hd mounts.
idkew is offline   Reply With Quote
Old 06-20-2006, 03:37 PM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
guy, sorry
i meant the proper way to do it, w/o setting it up to leak gas, etc
there was a check valve, and some other stuff involved
Old 06-20-2006, 04:56 PM   #4
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Check valve to remove the canister?? No.
Not unless you are removing the entire system around it.
Charcoal canister is just 3 12mm bolts and 3 hoses, thats it.
Wedge is offline   Reply With Quote
Old 06-20-2006, 05:01 PM   #5
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
yeah i want to remove the entire canister system
Old 06-21-2006, 02:00 AM   #6
project_legacy
Member#: 114408
1999 Subaru Legacy L
30th AE Maroon
LoL. this obviously isnt getting anywhere. i think the check valve you are talking about is for the gas tank vent line? not sure which one it is though.
project_legacy is offline   Reply With Quote
Old 06-21-2006, 02:36 AM   #7
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
lol thnks....
Old 06-21-2006, 09:22 AM   #8
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Default I'm interested too.
I would be interested to see what the proper way to do this is as well. I have an SVX which has an electric purge valve instead of a check valve. I think the only thing we would need to do is plug the exit from the canister to the manifold. On the SVX there is nothing connected between them, but you should check that. I have not figured out what to do with the gas line from the tank. Right now I have it venting to atmosphere from the engine bay. Not thrilled with that setup. I was thinking of running it to the constant suction of the turbo, but I'm not sure how much vacuum that would create at the gas tank. Was also thinking of running at small tee with a little in line filter before it goes to the turbo. Perhaps that would keep the pressure higher, closer to atmosphere. I've also considered reconnecting it since it is not a performance killer.
cdigerlando is offline   Reply With Quote
Old 06-21-2006, 12:18 PM   #9
Subaruski
Member#: 39905
So are you guys removing the entire system for good? I know it has something to do with emissions but what are the benefits of removing it?
Subaruski is offline   Reply With Quote
Old 06-21-2006, 12:38 PM   #10
idkew
Member#: 99980
^+1
What are the benefits?
Old 06-21-2006, 12:50 PM   #11
maxiav
Member#: 40413
2001 BRP RS-T EJ257
Link'd - 252WHP 274WTQ
I think the check valve that you are talking about is what I did to my car. You hook up a check valve to the Purge control Solenoid on the manifold to avoid getting fuel smell inside the car... but you didn't have to remove the charcoal canister.
maxiav is offline   Reply With Quote
Old 06-21-2006, 01:01 PM   #12
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
No, kaos talked about a check valve in the tubing for the canister, at the rear of the car...something about gas vapor escaping
Old 06-21-2006, 05:10 PM   #13
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Default Why you ask.
I have installed an aftermarket turbo and parallel engine management. I've also ripped out the old fuel rail and most of the pipes associated with the purge system. I'm not sure it will work correctly anymore. If I knew more about how exactly it works to keep the gas tank properly vented and the fuel vapors purged, I would still use it. But I'm sure it would need to be modified for my application.
Old 06-21-2006, 07:00 PM   #14
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Im Not Talking About The Purge Control Solenoid!
Old 06-23-2006, 05:02 PM   #15
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Default Purge Control System.
Is not the canister a part of the purge control system?
Old 06-23-2006, 05:09 PM   #16
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Yes...but I am talking about plugging hoses at the rear end of the car, not in the engine bay, I dont even have a purge control solenoid on my car
Old 06-24-2006, 09:30 AM   #17
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Default Purge Control.
I would check the RS vacuum diagram. I have only seen the SVX diagram, but if you plug the line the the fuel tank you run the risk of collapsing the tank under vacuum. I thought about plugging the vent line and installing a vented gas cap. That is up to you. I would really prefer to run the line to a light vacuum on the intake somewhere. Good luck. Too bad no one responded to this post with instructions as to how they did this. I did a number of searches on this site and came up empty.
Old 06-24-2006, 02:48 PM   #18
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
yeah totally
thanks man
alex
Old 07-05-2006, 01:14 PM   #19
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
dsgdfg
Charcoal Canister Removal- Can it be done??? deebee8 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 06-20-2011 05:26 PM
What's the solenoid just above the charcoal canister? mc2 Normally Aspirated Powertrain 3 02-25-2009 03:38 PM
whos got pics of the wrx in initial d? krillz General Community 38 03-07-2006 04:18 PM
So who got in on the Google IPO? SkirtBoy Off-Topic 5 10-22-2004 01:42 PM
can my wrx live with out the charcoal canister? zavala Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 05-15-2004 01:39 PM
