Old 06-20-2006, 07:09 PM   #1
jebjkey
Member#: 73884
Chapter/Region: HIIC
16 HyperBlue STi
16 Crystal White STI
Default Screen shot of my 93 oct 04 WRX ST map
I posted this as a response in another thread, but I figured it should be in a thread of its own.
04 WRX with the following mods of concern:
Cobb SF short ram
VF30
USDM STI intercooler
walbro 255 lph fuel pump
STI pink injectors
one step colder copper spark plugs
Borla headers
gutted uppipe
Cobb catted TBE
LC-1 wideband
Dynamic advance is 4.94 for all cells
OL/CL delay is 0 for all cells
jebjkey is offline   Reply With Quote
Old 06-21-2006, 08:30 PM   #2
xFactor
Member#: 65470
02 Hong Norr Wrx
rock chip red
All right! Somebody else stepped up to the plate!
Some questions;
What peak loads do you hit? I noticed your map is scaled to 3.0. Are the load values different for the 02... 2.14 was the highest factory load point, and I rescaled it to 2.5, and haven't gone off the scale...
What are your injectors scaled at?
How close do hit your ol target fuel values?
How are your trims?
I'm not implying anything, but damn that's a lot of timing! What does your learned KC table and your IAM look like on average?
Did you add 4.94* to all the load sites in the KA map, or leave the low load ones alone?
Did you also rescale the KA and the Learned KC maps?
What fuel do you use?
I'm sure I could think of some more...
Thanks man!
later, x
xFactor is offline   Reply With Quote
Old 06-21-2006, 11:53 PM   #3
jebjkey
Member#: 73884
16 HyperBlue STi
I have hit a load of 2.8x before, but since I mapped my intake, my loads peak at 2.6x mostly. I pretty much put the 3 on there because I knew I would not go higher than that.
Injectors are scaled at 4975
AFR's come in about .1 to .2 richer. 12's for spool, tapering down to about 11.1 at redline.
fuel trims are all <5% at pretty much every load. Many are 1-3%.
I use pump 93 oct from Cumberland Farms (Gulf) or Mobile.
Here are the DA and KC tables
Old 06-22-2006, 12:00 AM   #4
jebjkey
Member#: 73884
16 HyperBlue STi
On 5/31 I went to the drag strip, that data logs show timing at redline anywhere from 32-36.5 degrees depending on the gear and which run you look at, NO knock anywhere and intake temperature was 147 degrees when I lauched on the first run. It dropped to 97 by the end of the run and the second run went from 115 to 84.
Old 06-23-2006, 10:39 AM   #5
Wagun
Member#: 106433
2004 WRX wagon
What did you run at the strip?
Have you dynoed?
Wagun is offline   Reply With Quote
Old 06-23-2006, 03:33 PM   #6
jebjkey
Member#: 73884
16 HyperBlue STi
I was not there to get a good time (clutch near end of life), only to get a trap speed. I ran twice on 5/31: 13.06 @ 107.72 and 13.16 @ 107.88 (both had a ~2.0 60'). I had a dyno last year before I added the Cobb intake and with a different map, 253 HP/FT-LBS.
How do I do a screen shot of a video on my computer?? rice h8r Off-Topic 8 01-26-2008 11:34 PM
Looking for screen shots of Stock boost table from STi and WRX. KC Commercial ECU Reflashes 3 01-15-2007 01:51 AM
Cobb Stg2 93 oct w/ Injen CAI map wrxicon Engine Management & Tuning 1 08-24-2005 06:57 PM
A few quick shots of my Sunset Orange Metallic WRX lawn boy Member's Car Gallery 57 04-26-2005 01:15 PM
