Old 06-21-2006, 01:05 PM   #1
ohforesti
Member#: 114804
2004 WRX STi
WR Blue
Default CA residents: is the cobb stage 2 CAL worth it?
What i am asking is, with the cobb AP, you can either go with the stage 2 91/93 oct, or you can go with stage 2 CAL, which is referring to the fact that it makes up for cali's crappy gas, so is it worth it in california? or will you get more performance from the normal stage 2 map.
ALSO, how do you know if you 'should' be running the HWG, or LWG stage 2??
not really sure and i just got my AP yesterday...
thanks for any suggestions
ohforesti is offline   Reply With Quote
Old 06-21-2006, 01:30 PM   #2
gqchynaboy
Member#: 88529
I see that your from the Northbay, I would get a Protune!
gqchynaboy is offline   Reply With Quote
Old 06-21-2006, 01:33 PM   #3
ohforesti
Member#: 114804
2004 WRX STi
WR Blue
where? and whats the cost?
Old 06-21-2006, 01:35 PM   #4
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
gruppe-s
Bishop is offline   Reply With Quote
Old 06-21-2006, 03:12 PM   #5
gqchynaboy
Member#: 88529
Gruppe-s.com / $185 1hr and it usually only takes 1 hr for 1 map
Old 06-21-2006, 08:00 PM   #6
subywrx
Member#: 81858
Is it really neccessary for protune? I know its better but another $200?
subywrx is offline   Reply With Quote
Old 06-21-2006, 08:07 PM   #7
Bishop
Member#: 59993
Ass, grass or cash
a custom tune is always better than an OTS (off the shelf) map. is it necessary? no. if you plan to add more modes. i'd say. yes.
Old 06-21-2006, 08:11 PM   #8
ohforesti
Member#: 114804
2004 WRX STi
WR Blue
the reason i asked, is because i just got the AP yesterday, but i had been running a TBE for a few weeks now on the stock ECU. now that i reflashed(stage2 CAL), it doesnt seem like there is ANY boost in performance...in fact it seems to pull with alot less force...so i dont know, maybe ill try the normal stage 2 real time map, and see if thats any better. btw, what is the HWG and LWG stage 2 maps? and how do you know hwen you should use them?
Old 06-21-2006, 08:24 PM   #9
Bishop
Member#: 59993
Ass, grass or cash
why did you flash the CAL map? the CAL map and hwg map should only be used if you're havin issues. be it knock or boost. also give the ecu some time to learn. usually takes 300 or so miles.
Old 06-21-2006, 08:37 PM   #10
teiva-boy
Member#: 22825
It's possible that you are used to the slam in the seat effect of a stock car. Where a good tune is a more smoother acceleration, with higher torque/HP over stock.
teiva-boy is offline   Reply With Quote
Old 06-22-2006, 11:45 AM   #11
subywrx
Member#: 81858
So if I get my AP and use stage 2, which map should I be using (up pipe/dp/sti cat-back)?
Old 06-22-2006, 12:02 PM   #12
Bishop
Member#: 59993
Ass, grass or cash
try the 91 oct. map first.
Old 06-22-2006, 12:52 PM   #13
subywrx
Member#: 81858
What should I be looking/listening/feeling for? How would I know if 91 oct is right for my setup/car? I know I should drive it for around 500 miles for the ecu to learn the setting. Thanks
Old 06-22-2006, 01:27 PM   #14
Bishop
Member#: 59993
Ass, grass or cash
what year is your wrx?
Old 06-22-2006, 02:16 PM   #15
subywrx
Member#: 81858
04 WRX 5-spd
Old 06-22-2006, 02:26 PM   #16
Bishop
Member#: 59993
Ass, grass or cash
you should be fine w/the 1.30 91 oct. map. IF you do run into any issues. we have an accessport forum here on nasioc or you can always head over to the cobb forum.
Old 06-22-2006, 02:37 PM   #17
subywrx
Member#: 81858
Thanks J*Bishop
Old 06-22-2006, 02:42 PM   #18
Bishop
Member#: 59993
Ass, grass or cash
anytime!
Which is faster? Cobb Stage 2 or UTEC Stage 3 disque71 Engine Management & Tuning 17 07-02-2005 11:01 AM
prodrive stage 2 isn't worth it Chewyguru Brakes, Steering & Suspension 4 10-25-2003 03:11 PM
Cobb Stage 1 suspension: worth it ? FloridaWRX Brakes, Steering & Suspension 11 08-27-2002 03:48 PM
Is the WRX Sound Package upgrade worth it? dubrx Car Audio, Video & Security 20 05-08-2002 12:58 PM
