Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 06-22-2006, 12:54 AM   #1
03scubaru
Member#: 83557
PSM Now with 405 whp
Default Hydra: Car won't stay running after install
Installed my Hydra tonight and loaded the base map from Phil. The car will start and spit and sputter for about 5 seconds then just die. Need some help.
Thanks
Justin
03scubaru is offline   Reply With Quote
Old 06-22-2006, 08:38 AM   #2
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Thanks
Justin
You need to contact Phil directly (if you did buy the Hydra from Phil). He will take care of you on it. Not to mention for help on here from others you would need to at least list all of your mods.
offset
PS Roughly where at in Ohio are you?
offset is offline   Reply With Quote
Old 06-22-2006, 09:13 AM   #3
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Justin,
Go ahead and give me a call today so I can help you out. First "upload" the map that is currently in your Hydra and email it to me so I can make sure you've downloaded the map correctly. 9 out of 10 times this is the problem.
I can call you back once I review your map.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 06-22-2006, 09:47 AM   #4
Element Tuning
Member#: 54918
673 WHP Element
Thanks
Justin
Justin,
I just realized looking at my notes that I never emailed you a map. The map was already programmed into the Hydra so no downloading was required.
Thanks,
Phil
Old 06-23-2006, 03:07 PM   #5
03scubaru
Member#: 83557
I am from Columbus, Ohio. My mods are built bottom end, rotated mount t3/t4 50 trim, 850 cc injectors, greddy fmic all the rest of the basics.
Old 06-23-2006, 04:16 PM   #6
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
If you turn the key to 'ON' without starting the car and let the WB02 sensor warm up for 30 seconds, then start the car, what AFRs are you seeing?
jblaine is offline   Reply With Quote
Old 07-22-2006, 06:14 PM   #7
03scubaru
Member#: 83557
Just got back from a long vacation tried warming the wideband and still won't start.
Old 07-24-2006, 12:20 PM   #8
03scubaru
Member#: 83557
if anyone around this area has hydra experience and would want to help me get my car running I would be willing to pay you.
Old 07-24-2006, 12:28 PM   #9
WhiteKnight
Member#: 56133
2004 Euro spec Sti
Black - Rotated gt3037s
What is your AFR after you turn-on the ignition and wait for about a min ?
WhiteKnight is offline   Reply With Quote
Old 07-24-2006, 02:36 PM   #10
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
I would offer to help if I felt more competent with the tuning of the Hydra (I am only brave enough to risk ruining my car, not someone else's). But you might try calling Bryon at Meade Engineering. He has gotten some positive reviews from some of the other local guys in general tuning ability; I believe he has worked with a couple of Hydras as well.
http://www.meadengineering.com/
[email protected]
614-771-1110
offset
Old 07-24-2006, 02:57 PM   #11
ryanpietro
Member#: 101803
2005 gt35r sti
blue
don't touch your car until you talk to phil is my reccomendation. its not worth blowing a motor over being impatient. have you spoke to him yet?
ryanpietro is offline   Reply With Quote
Old 07-24-2006, 04:38 PM   #12
03scubaru
Member#: 83557
the afr goes as low as 8.1
MY97 Impreza 2.2L -- Cleaned MAF, now car won't stay running Nihilator Normally Aspirated Powertrain 29 09-06-2015 04:12 PM
Hydra: Car won't stay running entropy138 Other Engine Management 5 12-03-2007 10:33 AM
Car won't stay running TylerC21 Service & Maintenance 5 08-21-2006 08:42 PM
My car won't stay running.....Utec Pacobeagle Engine Management & Tuning 5 09-18-2005 07:33 AM
HELP.. car won't stay running WRXonmind Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-12-2004 05:40 PM
