Old 06-22-2006, 11:30 AM   #1
JoshP
Member#: 94350
Default pic of 2.5 head gasket on 2.2 head
a lot of people were wondering about the mismatching of 2.2 heads compared to 2.5.
Im going to cut mine personally. This is p2 gasket on p1 head, I wonder if p2 2.2 heads line up better? I suppose I should mention frankenstein for the searchers.
this is what the head looks like:
JoshP is offline   Reply With Quote
Old 06-22-2006, 01:24 PM   #2
Russell Rogers
Member#: 27261
I'm Ron Burgundy?
That gasket is blocking water passages. I wouldn't cut gaskets either, it degrades the strength built into it. just get the correct gasket for the head.
Russell Rogers is offline   Reply With Quote
Old 06-22-2006, 01:47 PM   #3
JoshP
Member#: 94350
thanks for pointing out the obvious. The heads are going on a 2.5 shortblock, the 2.5 gasket is used.
Old 06-22-2006, 02:03 PM   #4
Rally_wgn
Member#: 62629
1996 OBS in Green
2.5 N/A w/ full exhaust
Watching this as I am planning on a frankenmotor myself.
Rally_wgn is offline   Reply With Quote
Old 06-22-2006, 03:55 PM   #5
JoshP
Member#: 94350
something that was discussed on another forum is that the 2.2 turbo heads use the same coolant passages, and would line up much better. You can use the turbo heads in an n/a you would have to block off the oil and coolant feeds though.
Old 06-23-2006, 12:01 PM   #6
opious
Member#: 57718
99 Impreza OBS WGN
Silver now w/ 20mm rear!P
Subscribe!
opious is offline   Reply With Quote
Old 06-23-2006, 12:49 PM   #7
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Unfortunately though the p.2 2.2 heads are single port exhaust.
Tim Sanderson is offline   Reply With Quote
Old 06-23-2006, 10:50 PM   #8
JoshP
Member#: 94350
I think you quoted the wrong post? I would use p2 heads any day, they have bigger valves. Stock p2 makes more power than p1 (2.2s). But I looked at a P2 head, and the coolant passages are the same. So they wouldnt line up any better with the 2.5 gasket. But, the 2.2 turbo heads are P1 (dual port) and have almost the exact same coolants passages.
Old 06-23-2006, 11:14 PM   #9
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Bigger valves huh? I'll have to take a look-see at the manuals again.
Old 06-24-2006, 01:26 AM   #10
JonofScio
Member#: 53595
1987 GL Hatch
EA81 1.6L + Weber
p2 uses same camshaft design and same valves as SOHC EJ25 head, FWIW. (I've researched part numbers, talked to gurus, and this is what I have come up with for information. but I doubt that I am wrong.)
And the phase II EJ22 makes slightly more power because of the bigger valves and slight bump in CR. (9.5:1 to 9.7:1) but I think it is an overall better torque curve. if you look at the dyno numbers, which can be found easily, just referencing to the peak hp/tq numbers, the phase II motor has a little more (like less than 10 in both areas) but offers it up quicker in the rpms... but this could be do to camshaft too, so who is to know which of the two heads is really all that much better?
I think flow charts of stock heads/valves would really show what differences in performance expecation and ability wise they both have. the biggest turn off of course of the phase II is that it is single port, and that turns most people off because of the effects of a well designed exhaust with dual ports can peform good scavenging, ect. but I have no real world diagnosis of whether this is really an issue for comparison for these heads or our motors... this is alot of rambling, but I get bored and don't get on here much. maybe there's some useful info here for those who care.
also, head shots... need to compare water passages.... I wonder if the p2 ej22 blocks and heads have the same overall design of passages, ect. as p1/p2 ej25 blocks/heads but are just at a slightly smaller piston bore and head combustion chamber shape. has anybody gotten REAL cc numbers on p1 and p2 EJ22 head combustion chambers? I'd like to see those numbers.
Most of the people running EJ22/EJ25 frankensteins are using p1 heads I do believe. if bigger valves is an issue and dual ports are a must, you can always get bigger valves made and your heads machined. don't forget that for less than $500 TWE can do a 5 angle intake and 4 angle exhaust valve job on our subie heads and that IMO is a huge improvement overall and is not to be overlooked when comparing using the p1 versus p2 argument of "bigger valves" as the only solution to more airflow.
/rant
JonofScio is offline   Reply With Quote
Any pics of 18x8.5 rota grids on a bugeye ? Serkan Member's Car Gallery 4 04-06-2009 02:07 AM
Head Gaskets on 98 2.5RS boostjuice Normally Aspirated Powertrain 0 03-23-2009 11:21 AM
pics of SSR competitions in gold on a 2.5RS coupe? soobyfan Brakes, Steering & Suspension 1 02-25-2003 02:41 PM
Head Gasket on Phase 2 engines cardin555 Legacy Forum 19 01-13-2003 10:34 AM
Pics of the UK WRX wheels on my 2.5GT Patrick Olsen New England Impreza Club Forum -- NESIC 22 03-15-2002 03:41 PM
