Old 06-22-2006, 11:59 AM   #1
dj_booduh
Member#: 70861
2005 Scoobie WRX
Default AP Map loading problems. Please help.
OK guys. So I am waiting to get a protune from Dan at Harman Motive, but in the mean time he sent me a VF22 street tuner map for my car so I can safely get up there. I went to go flash it into my car, but when I went to do so I got an error messege that said
"Low Voltage... Please check cables"
I checked all the cables, but I continued to get the same messege. Anyone know what might be the problem. I have checked the battery connections and grounds, but I am still getting this messege. Someone... Anyone... Please help. Thanks.
dj_booduh is offline   Reply With Quote
Old 06-22-2006, 06:47 PM   #2
boundy3
Member#: 54598
2004 WRX Sedan
WR Blue Pearl #68 STX
Is this a basemap or a realtime map?
If it is a basemap you need to connect the green connectors and short the initilization connector with the white plug.
It may also be that your battery is low, if so connect a battery charger during the flash.
boundy3 is offline   Reply With Quote
Old 06-22-2006, 06:54 PM   #3
johsti
Member#: 36049
2014 FXT Premium
Also make sure your car is in "test mode" (fans turn on and off intermittently). When it tells you to turn the ignition off, don't. Press ok, and basemap should load.
johsti is offline   Reply With Quote
Old 06-23-2006, 12:04 AM   #4
waktasz
Member#: 86356
2015 s1000r
wheelie monster
Hook your car to another car via jumper cables. I bet it works.
waktasz is offline   Reply With Quote
Old 06-23-2006, 12:38 AM   #5
SPIDEYWrX
Member#: 36109
YEP +1
SPIDEYWrX is offline   Reply With Quote
Old 06-23-2006, 01:31 AM   #6
dj_booduh
Member#: 70861
2005 Scoobie WRX
Fixed it. Thanks for the reply's. I ended up going to pep boys and using there battery charger. The map loaded right up with no problems. Thanks again people
Need help ASAP with smoking engine problem! PLEASE HELP! DJS_02_WRX Newbies & FAQs 14 10-10-2009 09:59 AM
sudden COBB AP problems, Please help zero-d AccessPort 3 09-29-2009 09:59 AM
COBB AP Q/problem please help :) mookies AccessPort 4 07-28-2008 07:24 PM
AP Map Manager problem carrman AccessPort 6 02-12-2006 02:33 AM
AP Problems, please help anthony_delprete84 Engine Management & Tuning 37 12-17-2005 02:30 PM
