Old 06-22-2006, 05:05 PM   #1
dpalo81
Member#: 106888
Default Grinding engine noise 02 WRX
Looking to see if anyone has ever heard this or better yet solved this problem? When the car is started in the morning there is a gringing sound that occurs every 2 sec, which tells me that it is definately something that is revolving that is causing the sound (like a metal rubbing sound) and last like 1 sec. It is comming from the left side of the engine (passenger side). With the car sitting there idleing the sound gradually get less lound until it goes away. It only happens when the car is relativly cold. When the engine is hot it does not happen at all????? HELP
dpalo81 is offline   Reply With Quote
Old 06-22-2006, 09:40 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
check the timing belt/cover!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 06-22-2006, 10:05 PM   #3
USF97J4x4
Member#: 83035
Yea sounds like timing belt
USF97J4x4 is offline   Reply With Quote
Old 06-23-2006, 11:14 PM   #4
dpalo81
Member#: 106888
not sure why the timimg belt would make sounds when cold, then go away when the engine is warm. i am not sure but does the belt spin the speed of the crank hence the sound would be alot faster? Remember that the sound happens like every a scrape per second and the engine revolves at idle about 600 times that speed? Please correct me if i am wrong? also if it is the timing belt how would i check that without changing the belt?
Old 06-25-2006, 09:02 AM   #5
dpalo81
Member#: 106888
Come on people there must be additional information that you guys may have?
Old 06-25-2006, 01:58 PM   #6
Smoby
Member#: 97642
2002 Wrx Sedan
MBP
You should try putting this in the 2.0l forum. I am curious also because I have this same problem.
Smoby is offline   Reply With Quote
Old 06-25-2006, 08:37 PM   #7
dpalo81
Member#: 106888
i just did thanks for the heads up, by the way expand more on your specific problem? and how long have you had it?
04 STI engine -> 02 WRX questions SpooksRex Subaru Conversions 3 10-01-2008 01:43 AM
Growling Noise 02 WRX turbobird14 Transmission (AT/MT) & Driveline 12 05-15-2008 06:11 PM
Clutch Rattle Noise 02 WRX killa996 Newbies & FAQs 6 01-29-2007 08:08 PM
Flywheel noise 02 WRX Yin Transmission (AT/MT) & Driveline 0 08-28-2005 09:08 PM
usdm sti engine into 02 wrx wrxracer55 Subaru Conversions 7 10-25-2004 01:22 PM
