Old 06-27-2006, 06:32 AM   #1
Bullitt 2496
Member#: 53724
2013 Subaru BRZ LS2
Default part throttle bucking after AP stage 3
I just swapped up to the VF39 map on my accessport, and ever since, I get a bucking feeling if I go light on the gas in 2nd gear. If I try to hold the pedal steady at part throttle, the car jerks hard and my boost gauge goes from boost to vac and back to boost quickly, and if I don't lift or put in the clutch, I feel like the drivetrain is going to blow up.
If I floor the car, it seems to build and hold boost fine (very quickly)
Has anyone else experienced this feeling?
Bullitt 2496 is offline   Reply With Quote
Old 06-27-2006, 08:37 AM   #2
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
...call cobb
Old 06-27-2006, 08:42 AM   #3
scooby24
Member#: 56414
2004 Forester XT 5MT
Sounds like you're hitting right on a crossover point. When it starts to do that if you lightly lift or give throttle does it go away?
scooby24 is offline   Reply With Quote
Old 06-27-2006, 08:48 AM   #4
JRSCCivic98
Member#: 67080
Did you use the stock TD04 bcs hoses on the new VF39 turbo? Cuz you have to...
JRSCCivic98 is offline   Reply With Quote
Old 06-27-2006, 08:52 AM   #5
scooby24
Member#: 56414
Which BCS hoses are you referring to? The one with the restrictor pill? I went out and bought the VF39 ones with pill and my car drives fine
Old 06-28-2006, 01:36 AM   #6
Bullitt 2496
Member#: 53724
2013 Subaru BRZ LS2
sort of... if i lift it'll buck to a stop and if i floor it it hits boost REALLY hard
Old 06-28-2006, 09:50 AM   #7
Valhakar
Member#: 39514
2003 WRX 2.5L Hybrid
Mostly Blue
I get that as well, its the OL/CL crossover and its a PITA. I just lift then push past the point to make it stop.
Valhakar is offline   Reply With Quote
Old 06-30-2006, 09:08 AM   #8
scooby24
Member#: 56414
I just installed my AP and my stage 3 has no buckling at all.
I looked over the manually and thought of this thread when it talked about it not being a smooth crossover.
Make sure you flashed the BASE map for the VF39 and then run the real-time map for the 39.
Old 06-30-2006, 09:11 AM   #9
Bullitt 2496
Member#: 53724
2013 Subaru BRZ LS2
ive never had to install a realtime map before... only base maps for stage 1 and 2... why is this different?
louder after ap stage 1 meatling AccessPort 7 09-22-2008 10:38 AM
Pinging after AP stage 1? Tyler H Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-23-2008 12:16 PM
FP Green STi part-throttle bucking ... help! nathansvt Engine Management & Tuning 24 12-20-2005 02:29 PM
06 Wagon before/after AP Stage 1 times sleestak6326 Proven Power Bragging 17 12-19-2005 12:36 AM
Part throttle boost with vishnu stage 0? Mephisto318 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-07-2002 08:16 PM
