Old 06-23-2006, 12:33 AM   #1
teh sash
Member#: 79329
Default HELP: Temporary Protune Base Map ~ AP Doesnt list the map
Ok, [email protected] sent me a map to safetly drive my car for the tune with the upgraded injectors, but here is the problem:
When I loaded the map on the AP with the cable on my comp it said that I had too many entries so I erased COBB Stage 2. After that I click the green icon to move the temporary protune map onto the AP. It says that it was successful BUT I cant see the map on my AP. When I look on my PC it says that Doug's map is loaded on number 2 Which is COBB Stage 2. But when I look on the AP it says that its just cobb stage 2 and not the map I uploaded on the AP. HELP! Is their a reason why its not being named? Or is it just there but named COBB Stage 2
teh sash is offline   Reply With Quote
Old 06-23-2006, 09:39 AM   #2
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Go to map manager and check the map properties for the map doug sent you. The name in the properties is the name that is listed on the AP. He probably just sent you a stage2 map w/ a modified injector latency value and didnt bother to change the properties.
Crystal_Imprezav is offline   Reply With Quote
Can the AP V2 show the base map? mmiller2002 AccessPort 7 12-17-2009 05:25 PM
Protune base map GREY - cant flash to car rubinm AccessPort 1 06-27-2009 11:06 PM
Cant change base map AP V2... BBBsti LTD Engine Management & Tuning 0 06-01-2007 12:00 AM
Help: Street Tuner install & AP Custom Map Sausage AccessPort 2 12-07-2006 08:01 PM
Should i be using the stage 1 realtime map or just use the base map ? wrxhunter Engine Management & Tuning 2 06-10-2005 12:38 PM
