Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 06-23-2006, 12:47 AM   #1
SilverBullet2.5RS
Member#: 96060
'87 VW Cabriolet
Default Erratic idle @..... idle.
Ok, so I've noticed today that when my car is in neutral at a stop light or whatever my car revs up to 1200 or so and then drops to 1000 and then down to 500. It sometimes goes back up and back down too, I've tried to
run with and without a/d and it dosen't really make much diference. The car has always done this when backing down hills too, so I'm not sure what's up with this, it's like the choke kicks on or something.
Anyone have a clue whats going on? It's not much of a bother, but it sure kills gas mileage.
SilverBullet2.5RS is offline   Reply With Quote
Old 06-23-2006, 07:19 AM   #2
WRX03
Member#: 20744
05 Baja Regal Blue
03 WRX Little Red Wagon
If it was a wrx I would 99% say dirty idle sensor. Take it to the dealer and hopefully they don't say "we couldn't find anything wrong with it"
WRX03 is offline   Reply With Quote
Old 06-23-2006, 08:16 AM   #3
DoggoD
Member#: 84239
2005 2.5 RS
Regal Blue
My car has done that since I drove it off the lot new.
I have found that this will stop, and will keep a steady idle if you turn the air vent directional knob off of the windshield settings, and make sure the AC is off. On my 05 its the 2 settings the farthest to the right.
This sounds kinda weard, but my theory is that those two settings somehow keep the AC pump active. Just set the air to come out the dash, or the floor, and this Erratic idle will stop.
Then again, it could just be my car that this works on. Nothing wrong with a car that has a little personality.
I definetly dont think anything is wrong with your car.
DoggoD is offline   Reply With Quote
Old 06-23-2006, 01:53 PM   #4
SilverBullet2.5RS
Member#: 96060
'87 VW Cabriolet
Ok, so today I tested it a little, changed the way I drive, ran air on and off, everything and it's still doing it. Sometimes after coming to a stop a lights, the car will rev from idle to 2k 4-5 times and then start idling normal, but coming down in 250rpm drops.
I got 280 miles out of this tank of gas with no hard driving, I normally get mid 300.
I'm seriously considering a trade in, end of the year.
Old 06-23-2006, 02:22 PM   #5
BoneStockTS
Member#: 80670
It says in the owner's manual that the AC does in fact activate on the two rightmost settings of the directional knob, regardless of whether the AC button is set to ON or OFF. So this is not something unique to your car, it is intended to behave that way.
BoneStockTS is offline   Reply With Quote
Old 06-23-2006, 02:23 PM   #6
BoneStockTS
Member#: 80670
Your car is still under the drivetrain warranty, why don't you take it in to the dealer for diagnosis and repair?
Old 06-23-2006, 02:47 PM   #7
Kyguy
Member#: 38705
'95 GM2 Rally Car
& '08 WRX
My '97 L was doing this with a bad spark plug wire.
Kyguy is offline   Reply With Quote
Old 06-24-2006, 03:07 AM   #8
SilverBullet2.5RS
Member#: 96060
'87 VW Cabriolet
Well tonight I drove the car to North Carolina and the weather there was rainy and cooler than it's been here (mid 90's) and the car seem to run fine, even once I got back home it was ok, guess my car dosen't like temps above 90. We'll see if the prob continues tomorrow.
