Old 10-16-2001, 11:58 PM   #1
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Default Custom fuel rails, intrest me. How hard is it
Got an EJ20T (1990-1994 year, yes there where EJ20's back then, ver123 equiv) but I don't want to use the injectors or fuel rails off of it. I want to make some new rails and still be able to maintain the EJ20T FPR.
can someone breakdown of parts needed and such?
I've read that you can use the fuel rails off a 99 RS and they'll fit this EJ20 manifold.
WRXwannbe is offline   Reply With Quote
Old 10-17-2001, 12:05 AM   #2
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Do a search on the custom fuel rail that someone did a couple months ago. He took the stock one and chopped it apart and made a better one. can;t think of who it was right now though
Eric
Eric SS is offline   Reply With Quote
Old 10-18-2001, 04:27 AM   #3
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
look man,
I've read that post a million times over. It just doesn't make any sense.
I need a breakdown in lamens terms.
Old 10-18-2001, 04:35 AM   #4
Andrew
Member#: 1170
2005 STi
you could change it into parallel lines. look for parallel fuel line mod.
Andrew is offline   Reply With Quote
Old 10-18-2001, 04:37 AM   #5
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
thats exactly what I've been thinking, but the different manifold entry point are baffling me.
Old 10-18-2001, 04:39 AM   #6
Andrew
Member#: 1170
2005 STi
if you got to parallel lines watch out for high idle fuel pressure.
Old 10-18-2001, 04:47 AM   #7
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
ok let me put is this way,
I have a fair amount of technical knowledge of engine internals, turbos, intercoolers, manifolds, trannys.
But my weakpoint is fuel delivery systems.
What can I read so that I may learn more about this. Then after I read the info, I can stop making retarded posts about what fuel rails I should get, since I have no idea.
But my pre-attempt was to match up what injectors and fuel rails are compatible with what types of intake manifolds.
Old 10-18-2001, 05:41 AM   #8
Andrew
Member#: 1170
2005 STi
i dont know if they have anything but www.howstuffworks.com might help.
Old 10-18-2001, 09:13 AM   #9
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
blaster88 is offline   Reply With Quote
Old 10-18-2001, 11:13 AM   #10
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
woaa,
outa my leage on that one. thanx for the attempts to make me a more digniified person.
Old 10-18-2001, 11:27 AM   #11
outback motorsports
Member#: 4084
Default injector rails
we have rails in stock w/injectors bosch style give us a call 714 994 5222
outback motorsports is offline   Reply With Quote
Old 10-18-2001, 01:09 PM   #12
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Heh, next project John?
Impreza Rider is offline   Reply With Quote
Old 10-18-2001, 01:52 PM   #13
outback motorsports
Member#: 4084
Default billet stuff
nah,we've had the rails,we now have billet oil fillers w/outback logo, along w/billet dipsticks,soon to have billet oil caps w/wrx logo.we also have remote oil filter attachment.
Old 10-19-2001, 10:20 AM   #14
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Shiv at Vishnu has Super Jammy Fuel Rails for about $400 (including new FPR). Outback seems to have a solution as well, though I am unsure of the price; they are nice guys though, so give 'em a call. Other than that, your only other option is to use some of the stock fuel rail tubing, hack it all apart, and create your own parallel rails. Basically, you take your fuel line from tank and 'T' it off and feed each side of the 'T' to each fuel rail. Off the back sides of the fuel rails (fuel return side) you 'T' them back together and then run a single line into your stock FPR. Then from the FPR you return it back to the tank.
Hope that helps,
-Jon
www.nothingserious.net
full vinyl car wrapping - who has done it? how hard is it to do? any issues removing? mattesonb Interior & Exterior Modification 121 08-07-2013 12:57 AM
How hard is it to chage the steering wheel? Bobalouy Interior & Exterior Modification 2 05-11-2001 10:03 AM
How hard is it to remove ABS? Thug New England Impreza Club Forum -- NESIC 4 05-02-2001 04:44 PM
how hard is it ODDJOB Texas Impreza Club Forum -- TXIC 8 04-07-2001 12:33 AM
How hard is it to install frt bumper? impretzel Interior & Exterior Modification 0 03-05-2001 07:44 PM
