Old 10-17-2001, 12:44 AM   #1
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
Default UR Pulley questions, Need help quick
I just installed an Unorthodox Racing Underdrive Pulley on my auto MY01. I got it from T.Rod...who has an manual....the belts don't fit....it causes slipping on the power steering pulley, causing a REALLY nasty sound....What could remedy this? a smaller belt?
The alternator is has high as possible and the belts are still loose.
Andres
ATX25RS is offline   Reply With Quote
Old 10-17-2001, 12:50 AM   #2
mitch808
Member#: 10228
2002 Subaru WRX
Generally when installing underdrive pullies you are required to install smaller belts. That is probably why you have what you have.
mitch808 is offline   Reply With Quote
Old 10-17-2001, 12:57 AM   #3
ATX25RS
Member#: 4597
no I have the right belts, the smaller ones.....it still slips.
Andres
Old 10-17-2001, 01:30 AM   #4
mitch808
Member#: 10228
2002 Subaru WRX
Well you said that you already have the adjustment maxed out. You might as well go for a even smaller belt, you still have some play left in the adjustment to do so.
But if you *think* you have the rights belts.. You may want to make sure that everything is on in the right places. Perhaps you have the wrong belt on in the wrong place? Or something along those lines.
Old 10-17-2001, 01:36 AM   #5
ATX25RS
Member#: 4597
I am just going to try a 33" belt I think I tried 32.5"....too small...the other one is 33.5" I just couldn;t find it at this hour though. Should the belts be this different on an auto and a manual.....or does it have to do with ones a MY01 & the other is a MY00....
Andres
Old 10-17-2001, 02:24 PM   #6
SubyBean
Member#: 4367
1999 IMPREZA 2.5RS
Black :-( with dings
the belts are different for an auto and manual i know its too hard to find belts that fit on there i still havent found any.
andres if you have them on at the state meet make sure to get the part #'s bec i have an auto also
SubyBean is offline   Reply With Quote
Old 10-18-2001, 01:51 PM   #7
ATX25RS
Member#: 4597
I found them at O'Reilly's they are k050330 from Gates, so far they are te only brand that makes 33" belts in 5 grooves. In all of Austin, only one place has them and they only have one.
Andres
Old 10-19-2001, 03:30 AM   #8
ATX25RS
Member#: 4597
Alright Brian, I went and bought that belt....didn't work, it was to short. I tried a 335 and it worked fine...the one Toby (t.rod) gave me was a 336 and was probably strecthed because the new one fits very tight.
Andres
Car no longer makes ugly noises
tgv delete install question? need help quick!! pvalenza Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 05-01-2010 03:53 PM
Coolant Conditioner Question NEED HELP QUICK KoldKermit Service & Maintenance 6 02-26-2010 05:02 AM
Clock pod wiring question, need HELP quick shamrock 05 Interior & Exterior Modification 6 10-20-2008 12:24 AM
Need help quick crank pulley brandonbeeb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-01-2007 01:57 AM
Elementary physics question? Need help quick! desiwrx02 Off-Topic 16 09-18-2003 09:08 AM
