Old 10-17-2001, 12:50 AM   #1
wrxinfx
Member#: 10515
2002 WRX Sedan
Question Rattle while decelerating in 3rd gear
My rex has only 2500 miles on it and it has a weird rattle while decreasing under engine compression (not using brakes) in 3rd and sometimes in 2nd, especially with mid-high reves like 4k+.
I suspect a heat shield or similiar, but don't know - this is my first Subie.
thx in advance.
w
wrxinfx is offline   Reply With Quote
Old 10-17-2001, 08:10 PM   #2
TheWRX
Member#: 10279
2005 Lotus Elise
Yellow, #94 SS
This is a common problem with the WRX, you will find a lot of discussion of it if you a search, mainly in the retired WRX forum. I just started a new thread with my latest "insights" on the "Warranty Issues & SOA Problems" forum today, it's titled "WRX deceleration noise update".
TheWRX is offline   Reply With Quote
Old 10-18-2001, 12:18 AM   #3
wrxinfx
Member#: 10515
2002 WRX Sedan
Thanks - I'll watch that thread.
Old 10-18-2001, 01:15 AM   #4
BADWRX
Member#: 3792
2002 6MT almost GDB
Default It is really nothing...
It is the turbo heat shield...if you do not like the noise...just remove it!
Andy
BADWRX is offline   Reply With Quote
Old 10-25-2001, 08:32 PM   #5
Andursun0013
Member#: 11616
1998 2.35RS-T
2006 Baja 2007 Leg. Wagon
I had the same problem, only it was the heat shield where the headers join. Removing it wasn't necessary, some small rocks got in there and just need to be taken out.
Andursun0013 is offline   Reply With Quote
strange rattling/grinding noises in 3rd gear envision22 Newbies & FAQs 0 08-31-2009 05:03 PM
weird rattling/grinding noise in 3rd gear envision22 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-31-2009 04:03 PM
Rattling in 3rd Gear?? mynameischris Transmission (AT/MT) & Driveline 5 04-18-2007 02:05 PM
Clutch decel rattle in 3rd gear fordfabwiz Warranty Issues & SOA Problems 8 08-15-2002 12:47 AM
Shifter vibrates (pulses) while in 3rd gear. Maniac Transmission (AT/MT) & Driveline 2 06-26-2002 02:51 AM
