Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 06-24-2006, 12:33 AM   #1
CryderSpeed
Member#: 88816
TO TWERK
Default base or realtime map?
Noob question here, but a little on the technical side. I currently have the Stage 1 base map in 91 octane and want to start running a 93 map, but the question is, base or realtime? 93 is kinda hard to come by around here, however the station closest to my house has it. Would it be better to run a 91base with a 93 realtime or vice versa?
CryderSpeed is offline   Reply With Quote
Old 06-24-2006, 07:00 AM   #2
jebjkey
Member#: 73884
Chapter/Region: HIIC
2016 STi
HyperBlue
If 93 is hard to come by, then leave the 91 base map there and run the 93 realtime map when you have 93. Just be careful because filling up with 93 doesn't mean you have 93 in the tank. If you use 91 and then fill up with 93 you should have as little fuel in the tank as possible so you actually come out close to 93. There is no difference between a 91 base/93 realtime and 93 base/93 realtime so there is no reason to flash your ECU again. The stage number for the basemap is all that matters if you are going to run a realtime map on-top of the base map (which is not necessary unless you use a different realtime map then your base map).
jebjkey is offline   Reply With Quote
Old 06-24-2006, 08:01 AM   #3
CryderSpeed
Member#: 88816
TO TWERK
OK, so I'm a little confused, so what you are saying is that if my realtime map is different than my base map(say 93 vs. 91) it takes precedence over the ase map?
Old 06-24-2006, 08:55 AM   #4
hauntedwrx
Member#: 115104
2003 WRX
Sedona Red Pearl
Just keep your current 91oct base map, there is no real power gain by running the 93oct map. To me 5hp just isn't that big a deal. Your real time map overlays your base map on certain parameters, not all though.
hauntedwrx is offline   Reply With Quote
Old 06-24-2006, 12:42 PM   #5
hondaeater69
Member#: 60324
Originally Posted by CryderSpeed
93 is kinda hard to come by around here...
My advice is if you don't have 93 readily available, then stick with your 91 octane and 91 base map.
Old 06-24-2006, 05:54 PM   #6
jebjkey
Member#: 73884
2016 STi
HyperBlue
A realtime map will override certain tables in the base map. That is why you can run something like an anti-theft map and have the car not run at all.
Old 06-24-2006, 09:54 PM   #7
yuccasyrup
Member#: 118416
Might be a dumb question, but I guess I'm scared to F-up the reliability of my car like everyone else. We only have 89 and 93 oct gas in TN so obviously I'd go with the 93 map, but what are the chances of getting a bad tank of gas and it running like crap. Shouldn't mess up the engine I would hope. Also, anyone who has gone stage 2, did you install the TBE and then reflash, or reflash and then install the TBE, or does it even matter? Thanks for any help.
yuccasyrup is offline   Reply With Quote
Old 06-24-2006, 10:17 PM   #8
jebjkey
Member#: 73884
2016 STi
HyperBlue
Go with the 93 map, you will be fine as long as you fill up on 93. It does not matter if you flash the map and then install the TBE or vice-versa, what matters is that you do them together.
"Show Current Map" Option show base or realtime? cwepruk AccessPort 3 10-09-2006 03:09 PM
Base Vs. Realtime maps - CAP NattiRex Newbies & FAQs 19 06-02-2006 04:24 PM
accessport wont flash new basemap or realtime map... wrxraaca Engine Management & Tuning 3 08-09-2005 10:05 AM
Should i be using the stage 1 realtime map or just use the base map ? wrxhunter Engine Management & Tuning 2 06-10-2005 01:38 PM
Base map, Realtime map CaptainMorgan Engine Management & Tuning 2 05-15-2005 01:45 PM
