Old 06-24-2006, 09:52 AM   #1
MikalsWRX
Member#: 40702
2002 Wagon stg 3.5
Default A couple of questions on the EcuTek
If its been tuned to run 93 octane. If I was to add 104 to go to the track, would it make any difference? I was told it wouldnt. Also I heard that the rear window defroster button can be used to change maps on the EcuTek if its tuned that way? I think Subaru of Jacksonville does this?
Also, my friend had an 02 WRX tuned with an EcuTek and he totalled it. So I took everything, his sti pink injectors, his turbo( greddy T518z), his down pipe, fuel pump. The only difference is I have an injen FMIC he had a greddy fmic. I also have an Sti up-pipe he had Injen. We swapped out ECU's. His car was tuned for 1.4 bar and No boost controller. I have an EBC. SO we just hooked up with the EBC and my car has been runing great, also at 1.4 bar. Was talking to a EcuTek tuner and he told me that the car MIGHT run better without the EBC since it was tuned to run without one. Well we took the EBC off and put it to stock. The car was only running at 1 bar at WOT and not pulling as hard. I thought maybe the it had to go through some learning process. SOme times when I ran WOT it would go to 1.2 bar then back and stay at 1 bar. After a week of driving. I want back to the EBC and the car is running back at 1.4 bar. Im planning to get a reflash as soon as my headers get back from getting coated. Just wanted to know if anyone knows why this would happen. Thanks Mikal
MikalsWRX is offline   Reply With Quote
Old 06-25-2006, 05:40 PM   #2
MikalsWRX
Member#: 40702
2002 Wagon stg 3.5
bump^^^^^
Old 06-27-2006, 02:31 PM   #3
MikalsWRX
Member#: 40702
2002 Wagon stg 3.5
No one has any ideas On any of the questions
Old 06-27-2006, 10:31 PM   #4
Tea cups
Member#: 103136
No, it wouldn't make any difference, in fact, it probably run worse unless you were having a ton of detonation problems on the 93.
Tea cups is offline   Reply With Quote
Couple of questions on some DIY's JDM555 Interior & Exterior Modification 63 03-27-2008 08:56 PM
Couple of questions on sightings... rice h8r Tri-State Area Forum 3 11-01-2005 09:54 PM
Couple of Questions on 05 WRX Wagon Murf_68 Newbies & FAQs 11 02-26-2005 08:25 PM
A couple of questions on intercooler sprayers. BIGSKYWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-18-2003 05:40 PM
A couple of questions about the up-pipe dannyboy7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-14-2001 05:05 PM
