Old 06-24-2006, 12:01 PM   #1
hondaeater69
Member#: 60324
Default ST reinstall question
I have to reinstall the Street Tuner software on to my laptop, anyone know of a way to do this without having to unmarry the AP from the car and redo all that? The AP is already married to my ECU and also to the ST program, but now that i have to reinstall, it wants me to revert back to stock and reinstall onto to AP. Any idears? I just want to run ST again, not spend the next hour unmarrying and uninstalling AP SW etc etc. I would have called cobb had i thought about this situation prior to the weekend
Old 06-24-2006, 01:59 PM   #2
crazymikie
Member#: 56321
2006 Honda El Camino
Green
Replied on wrxforum, but have you tried one of the updaters here:
http://www.wrxforum.com/cgi-bin/ulti...;f=14;t=000084
crazymikie is offline   Reply With Quote
Old 06-24-2006, 02:10 PM   #3
hondaeater69
Member#: 60324
negatory, update doesn't work, error message reads "previous installation not found!". I don't have any of the ST SW installed any more, this is completely different laptop. I'm thinking i'm going to have to unmarry the AP, probably get all the ST SW off the AP, and competely reinstall reflash etc. what a PITA.
Old 06-24-2006, 02:59 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
no-no-no.......I have had ta do the same thing......several times, now ....farking HP laptops suck ballz
what ya gotta do is re-load the AP and ST software on the laptop....plug the AP into the laptop and get the map manager ta connect to and recognize the AP---ya may need the 'patch' from Cobb as I did......and the ST should be all good ta go.
...NO NEED ta 'un marry' or any of that jizz....NO----NOT
Old 06-24-2006, 04:25 PM   #5
Valhakar
Member#: 39514
2003 WRX 2.5L Hybrid
Mostly Blue
Uncle Scotty to the rescue.
Valhakar is offline   Reply With Quote
Old 06-24-2006, 04:35 PM   #6
hondaeater69
Member#: 60324
ok i'll try that when i get my AP serial cord from my other house . at least i don't have to unmarry the AP and all that jazz. thx.
Old 06-24-2006, 05:21 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
...make sure ya get the RIGHT cable....that cable is a 'null modem' cable....ya hafta use the right one......a regular serial cable won't work and 'gender changers' won't either
Old 06-24-2006, 07:05 PM   #8
hondaeater69
Member#: 60324
yes i know, that's why i said i have to get my "AP" serial cord and not just a serial cord
Old 06-27-2006, 11:27 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
W E L L ? ? ? ? ?
Old 06-28-2006, 09:38 AM   #10
hondaeater69
Member#: 60324
I won't have to chance to drive out to my townhouse to get the cord until this weekend.
Old 11-25-2006, 10:13 AM   #11
hondaeater69
Member#: 60324
1. where is this patch
2. did you get an error message when trying to sync your AP? I am getting an AP not recognized please contact tech support in my AP manager.
(AP is still married)
Old 11-25-2006, 10:37 AM   #12
hondaeater69
Member#: 60324
ok i found the map manager patch, and now i can sync the ap with the map manager etc.
BUT, when i go to reinstall ST, it says must connect to AP yada yada.. a screen says "you must first unmarry AP before installing ST yada yada" if this is done press yes to contintue, i press yes and it says an error has occured please check all connections. like it's not reading the AP. the AP is in sync mode...
Old 11-25-2006, 01:00 PM   #13
hondaeater69
Member#: 60324
bumpity... i decided to just unmarry the AP and try that... SAME flakin error message.
AP is updated with latest mapmanager/patch, i know the connection is good because i can communicate with map manager/import exports map, so why can i not continue with the install of ST?
after i get to the part where it says please sync AP and hit continue, i get this: "an error occured while updating the accessport. Please verify all connections. Do you wish to retry?"
grrrr
edit: just tried a different COM port. again, works with map manager etc, but still doesn't regonize AP when installing ST SW>
Old 11-27-2006, 10:44 PM   #14
05redrex
Member#: 86665
2005 WRX SRR 2.5/20g
2010 FXT SWP Cobb Stg2+
Have you seen this thread?
http://www.cobbforums.com/forums/sho...cured+updating
If you still have a problem you could try COBB support, or pm Christian.
05redrex is offline   Reply With Quote
Old 11-27-2006, 10:46 PM   #15
hondaeater69
Member#: 60324
scoobdude was kind enough to email me a more recent version of ST and it worked like a charm.
thanks again scoobdude!
Old 11-29-2006, 10:04 AM   #16
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
Never a problem.
scoobdude is offline   Reply With Quote
Old 11-29-2006, 01:23 PM   #17
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
Which version did you originally have and which version did scoobdude send you?
I ask for purpose of archival, etc.
parker/slc/gc8fan is online now   Reply With Quote
Old 11-29-2006, 01:39 PM   #18
hondaeater69
Member#: 60324
the one that was sent to me via scoob is 1,0,6,5 build date june 15 2006.
the other one i'm not sure of the version because it's not installed so i can't get to that screen but it's the on the disk that was shipped when i originally bought street tuner. not sure when i bought it exactly, but IIRC it wasn't too long after it came out.
ARE Cap Removal/Reinstallation Question davecoon13 Baja Forum 1 01-28-2009 05:18 PM
ST Map Question gaewsky1 Engine Management & Tuning 3 10-11-2005 09:55 PM
ST vf23 question 7point62 fmj Engine Management & Tuning 3 10-01-2005 11:34 AM
Falken Azenis ST-115 questions... Corey Motorsports 6 01-20-2004 12:16 PM
St. louis question..... XROLLER Mid West Subaru Owners Club Forum -- MWSOC 0 09-09-2003 11:57 AM
