Old 10-17-2001, 03:27 AM   #1
adamsrs
Member#: 3768
Default Will 02 WRX catback exhaust fir my rs-t
Just as it says: I want to buy that HKS Carbon Titatnium catback exhaust for sale in the vendor classifieds. Will it fit my RS turbo? Or will any WRX system fit my car?
adamsrs
adamsrs is offline   Reply With Quote
Old 10-17-2001, 04:20 AM   #2
8Complex
Member#: 922
04 FXT
Red
I know for a fact that if you're fitting a muffler-section only, you will need to rotate the flange and move the middle hanger forward (backward) an inch or two. Only the latter should be any trouble, however I'm not sure how the rest fits or if the hangers there will match up, let alone the flange.
I know, not much help, but I don't think anyone has actually done it yet.
Old 10-17-2001, 06:05 PM   #3
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
I know joe z tried to fit my Apexi N1 catback exhauston his WRX prior to me going turbo. There was the hanger issue mentioned abover as well as one other thing. You'd have to PM him for details though.
Fitz
Fitz is offline   Reply With Quote
Old 11-15-2001, 11:07 AM   #4
Boostup!
Member#: 552
SOHC RS-Turbo EJ257
Tec-2 Aquamist 2D
Has anybody found more info on this? i.e. will WRX catbacks fit RS-T.
Hanger locations should be easy to modify, I am just concern about the location of the front end of the pipe (flange) where it connects to the WRX factory cats. Will this location be the same on an RS?
Boostup! is offline   Reply With Quote
Old 11-15-2001, 01:28 PM   #5
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Why would you want to use a WRX factory exhaust on a RS-T?
kastle is offline   Reply With Quote
Old 11-15-2001, 01:38 PM   #6
scootr
Member#: 2649
00 2.5RS-t cpe BRP
64 chevelle SS
I am using a WRX dowpipe-back for my RS. Everything seems to bolt right up except the exhaust hanger behind the muffler(looking from the back). I am using this setup because it is a good size tubing and is already made for a turbo car. The downpipe sits higher and I had to have a custom intake piece made that bolts on the turbo. Otherwise the dual tip looks great and maybe cops won't suspect me having a aftermarket muffler etc.
scootr
scootr is offline   Reply With Quote
Old 11-15-2001, 05:14 PM   #7
Boostup!
Member#: 552
SOHC RS-Turbo EJ257
Tec-2 Aquamist 2D
kastle--I do not want to use a factory wrx catback. I meant aftermarket wrx catbacks, but hey.........if the factory wrx catback will fit, then all aftermarket ones should fit too, right?
I don't know yet where the Vishnu turbo kit downpipe will be located (the outlet part). So from the info here, it sounds like I can use any wrx after market muffler section and just custom make a midpipe section that will connect the downpipe outlet to the inlet of the muffler section. Hmmmm........interesting! Maybe I can save some money afterall.
The reason I am inquiring about wrx catbacks is because there are not too many catbacks available for RS-Ts, 3" at least.
FS: 02 WRX Catback Exhaust Tokinwhiteguy NWIC Private Classifieds 1 03-17-2010 04:08 PM
FS: CA 02 WRX Catback Exhaust subiebreadman Engine/Power/Exhaust 6 07-03-2007 01:10 AM
will 02-03 catback exhaust fit on an 05? Svenerachi Factory 2.0L Turbo Powertrain 5 04-23-2007 06:24 AM
Will 02 WRX wheels fit 00 Impreza RS? tankboy Brakes, Steering & Suspension 8 01-16-2002 06:52 PM
Message Board Statistics All times are GMT -4. The time now is 10:34 AM.
