Old 06-24-2006, 11:37 PM   #1
dpbgst13
Member#: 106582
2002 Suspension mod
Siegel Tuned FP GREEN
Default Cobb ap stage 2 w/o uppipe
Ok ive been looking for a while. nothing.
everyone talks about a tbe with the stage 2 cobb AP. I had a Mistu gst and tbe was all we had. I have an uppipe but its not installed yet. Am i ok to run stage 2 with out the uppipe installed or should i wait till that gets put in?
dpbgst13 is offline   Reply With Quote
Old 06-25-2006, 12:29 AM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
An up pipe is not needed for Cobb stage 2. You are O K to run stage 2 with or without doing the up pipe.
wrxdrvr is offline   Reply With Quote
Old 06-25-2006, 03:22 AM   #3
subywrx
Member#: 81858
big different with catless up pipe. I just installed mine today and I could tell the pick up is faster.
subywrx is offline   Reply With Quote
Old 06-25-2006, 08:32 AM   #4
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
Technically correct. But that won't save your turbo.
The UP cat is a ticking time bomb when you start feeding it EGTs that are significantly higher than stock. IMO, it's not worth the risk of destroying your turbo to leave it be when it really isn't that hard to remove.
If you haven't put your TBE on yet, wait until you have a gutted UP to throw on at the same time. Otherwise, you'll have to screw around pulling the DP a second time just to get to the UP. Do it all at once and then you'll never have to worry.
Spenk is offline   Reply With Quote
Old 06-25-2006, 08:37 AM   #5
scrwrx
Member#: 101523
I agree with ^^ I did all mine at once and it seems like a much better/stress free way. I dont have to worry about the uppipe burning up and ruining my turbo. I love my stage 2. I just know that once I get used to it I'll want more
scrwrx is offline   Reply With Quote
Old 06-25-2006, 12:13 PM   #6
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Oh... I forgot to add that I did do both, up pipe & the down pipe at the same time, for the reasons that others have said.
Old 06-25-2006, 07:08 PM   #7
rroberts
Member#: 103971
I thought the risk of the cat in the U/P coming apart was only with the use of a bigger turbo.I do agree however better safe than sorry. Definately not required for stg.2 though
rroberts is offline   Reply With Quote
Old 06-25-2006, 07:25 PM   #8
-Kevlar-
Member#: 82378
i still have yet to do mine.
-Kevlar- is offline   Reply With Quote
Old 06-26-2006, 03:40 PM   #9
EBWRC#1
Member#: 86843
Io Sono
a 500 Driver !
Humm...so I should buy one then!
EBWRC#1 is offline   Reply With Quote
Old 06-27-2006, 12:48 PM   #10
zettowrx
Member#: 83611
I'm about to install both soon. I just ordered a perrin up and a bosal shorty dp. Does anyone have experience with or heard of people running stage 2 AP with a shorty dp and the stock cat in the midpipe. I talked to Cobb bout it and the guy I talked to didn't recommend it. It's not an ideal combo, I agree, but it's my family hauler and I don't want my wife and kids complaining about the exhaust funk of a catless car. Thanks all.
zettowrx is offline   Reply With Quote
Old 06-27-2006, 01:49 PM   #11
SUPAREX
Member#: 28278
02 WRX
Platinum
I'm doing that and runs great!
SUPAREX is offline   Reply With Quote
Old 06-27-2006, 01:53 PM   #12
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
A shorty down pipe still meets the minimum requirements to run stage 2, so it should be OK you just miss out on a few pony's the full TBE would give you.
Old 06-27-2006, 06:39 PM   #13
Erexxx
Member#: 92054
2008 Mazdaspeed 3
Cosmic Blue Mica
Consensus is that you will be ok with stock UP, but get a catless one ASAP...
Check out this thread I created a while back...
http://forums.nasioc.com/forums/showthread.php?t=951353
Erexxx is offline   Reply With Quote
Old 06-28-2006, 02:09 AM   #14
johsti
Member#: 36049
2014 FXT Premium
Tough call. It could be fine, or it could be bad. Roll the dice. My CA stage 2 OTS map ran lean, and I ran it for about 10k miles with the stock catted UP, no problems.
I would recommend getting a catless UP, or at least get a tune to be safe. The catless UP won't provide much power, but your turbo will spool faster, and you won't have to worry about it breaking apart.
johsti is offline   Reply With Quote
Old 06-28-2006, 10:14 AM   #15
dpbgst13
Member#: 106582
2002 Suspension mod
Default uppipe
i have one. i just havent put it in bc my o2 sensor got stripped(w/o2 sensor tool) and we couldnt get off the heat shield(didnt have the right tool to cut it). So the up pipe is in the trunk waiting to be put on.
Old 07-04-2006, 08:17 AM   #16
zettowrx
Member#: 83611
Almost the same problem here. I didn't have the O2 tool, so I took a hacksaw blade and made like a prisoner from Alcatraz: slow and determined to get that metal cut. It was a PITA, but it worked. Hope you get it on soon.
Old 07-05-2006, 11:45 AM   #17
subywrx
Member#: 81858
I took the o2 sensor out like 4 times (friends/mine) never used a o2 tool, just a open wrench. Works fine for me.
Old 07-05-2006, 02:10 PM   #18
gh32
Member#: 9594
2005 WRX
I'm currently running Cobb's downpipe and Stage 2 with the stock uppipe until I can get it installed. I am actually seeing lower EGTs at WOT the way it is right now. With that said, I'm going to be installing the uppipe ASAP.
-George
gh32 is offline   Reply With Quote
Anyone Running Cobb AP Stage 2 Injen??? Red Rexx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-31-2004 12:09 AM
*** is Cobb AP Stage 2.5??? Red Rexx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-20-2004 11:49 PM
Cobb AP stage 2 with just TXS Stealthback? criz Engine Management & Tuning 13 10-13-2004 12:32 PM
Cobb AP stage 2 with headers? MFactor Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-21-2004 11:11 AM
Cobb AP Stage 2.5 installed casualsurfer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 09-14-2004 03:16 PM
