Old 06-24-2006, 11:38 PM   #1
Natoe
Member#: 90353
Sold '95 22T Impreza
'99 EJ205 L, AE86 GVR4
Default Best way to check for boost leaks
i just intercooled my EJ22T with a saab intercooler, and im getting a hissing noise even at idle, with the custom piping im just assuming there is a leak somewhere.
also, on boost my boost gauge will bounce/flutter between a couple psi, while it builds and at full boost... my guess was that the turbo was working extra hard creating this, since the VF-11 on here is a very small turbo.
also, after going on boost i can get it to backfire really bad, which makes me certain im losing air to a boost leak causing it to run rich...
SO, whats the best way to test for this and find my problem? i tried spraying carb cleaner everywhere and didnt find anything that way.
THANKS
Natoe is offline   Reply With Quote
Old 06-30-2006, 09:55 AM   #2
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
I'm getting the same sound. What did it end up being?
scoobyimprza is offline   Reply With Quote
Old 06-30-2006, 12:36 PM   #3
Natoe
Member#: 90353
i found out that the hissing is the BPV leaking at idle (Which is normal with this BPV) if i clamp the line from the manifold to it it stops but then idles really low..
i still get flutter and my boost gauge still bounces... i think it may be the hose clamps im using, since they dont stay REALLY tight like i want them to
Old 06-30-2006, 12:59 PM   #4
MonsterRallySport
Member#: 104148
MRT Spur cut with
Rocket center Diff.
If you want to get it checked out, Take it to a shop who has a smoke machine... They'll charge you about 4-5 tenths....
MonsterRallySport is offline   Reply With Quote
best way to check intake manifold leak? marcus.raw Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 11-09-2007 07:27 PM
Best way to check for BOV leak? txl146 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 12-16-2004 11:41 PM
Whats the best way to check for compression? nos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-01-2004 01:56 PM
What's the best way to check for exhaust leaks? wgknestrick General Community 5 02-20-2003 10:33 PM
Good way to check for exhaust leak garface Normally Aspirated Powertrain 7 03-06-2002 10:14 AM
