Old 06-25-2006, 12:02 AM   #1
ErasureWRX
Member#: 106408
'14 Mystery Machine
01 Kat600
Default Should I flash?
Just as the title says, I wanted to know if I should go stage 1 (just got my AccessPORT) and take my chances with warranty, or because I am at 28k miles should I wait until after my 30k service at the dealer's (afraid they would check my ECU and see mods). The 30k is all I'm worried about, not anything breaking and trying to have warranty repairs done
ErasureWRX is offline   Reply With Quote
Old 06-25-2006, 08:37 AM   #2
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
DOOOOO EEEEEEEET!
Stage 1 does not make parts start falling off your car, and the dealer will never know you've flashed the ECU if you don't tell them.
I went to Stage 1 at ~26K miles, and wished that I had done it at 1K. It makes a big difference on the '04/'05 cars, and you'll definately notice the benefits on your '02.
Spenk is offline   Reply With Quote
Old 06-25-2006, 09:27 AM   #3
-Kevlar-
Member#: 82378
Originally Posted by Spenk
DOOOOO EEEEEEEET!
x234524572456724747 dooooooooo eeeeeeeeeeeeet!!!!!
-Kevlar- is offline   Reply With Quote
Old 06-25-2006, 10:38 AM   #4
ErasureWRX
Member#: 106408
'14 Mystery Machine
01 Kat600
GONNA DOO EEEET!
On the way to my 45 minute drive to movie theatre So i'll have plenty of time to have fun with my new Stage1 goodness
Thanks!
Old 06-25-2006, 03:11 PM   #5
Got Torque?
Member#: 98694
2004 STi
white
Default yes, you should reflash
when you install an access port in your subaru, it marries itself to your ecu, and no matter what map you're currently running, you can always switch to the map that's designated, "married stock mode" or "revert to stock". This will hide the fact that you have an access port installed in your car. However, if you are really worried about it, simply "unmarry" it from your ecu before you take it to the dealerhip. They'll never know. Good luck man.
Got Torque? is offline   Reply With Quote
Old 06-25-2006, 03:43 PM   #6
wall of tvs
Member#: 29716
2006 wrx wagon
booze powered e85 monster
2002 and only 28000 miles?!?
Do you have the extended warranty? Otherwise your 3yr/36000 mile bumper-to-bumper should be up by now......
....and quit being a pansy, flash that sucker, AND START DRIVING IT!
wall of tvs is offline   Reply With Quote
Old 06-25-2006, 09:33 PM   #7
ErasureWRX
Member#: 106408
'14 Mystery Machine
01 Kat600
Yes, extended warranty, I bought it used at like 18k.
Gonna flash in the morning, it's a complete downpour outside and i hear electronics are no good when wet, haha.
I tried it earlier but gave an error, like check voltage or something. Any suggestions?
Old 06-25-2006, 10:15 PM   #8
wall of tvs
Member#: 29716
2006 wrx wagon
Check your battery.
Old 06-26-2006, 01:26 AM   #9
Bbasso
Member#: 66235
2005 WRX
could be the battery... But cobb had forgotten to send me that little jumper clip with my AP, Make sure you are using it (if needed on 2002 models)
Oh yeah, Flash the bitch, it's a great feeling once done.
Enjoy!
Bbasso is offline   Reply With Quote
Old 06-26-2006, 01:23 PM   #10
paulmofyourhand
Member#: 116355
2004 Impreza STI
bassboat JBP
was it a rumor that a new version of the Subaru diagnostic machines can detect prior flashing of the ecu?
paulmofyourhand is offline   Reply With Quote
Old 06-26-2006, 01:30 PM   #11
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
update?
fwiw: i normally let the car idle for about 5 min before flashing. why? i dunno...
Bishop is offline   Reply With Quote
Old 06-27-2006, 09:00 AM   #12
ErasureWRX
Member#: 106408
'14 Mystery Machine
01 Kat600
Update!
Still no flash, still getting *check voltage*.
I'm having my friend attach jumper cables from his car to mine next time.
And sacrificing children. It should work.
Old 06-29-2006, 09:52 AM   #13
ErasureWRX
Member#: 106408
'14 Mystery Machine
01 Kat600
Bump for help!
I attached jumper cables from a friends car and STILL got the 'low voltage: check cable'. Anyone? Bueller?
Old 06-29-2006, 12:29 PM   #14
Bishop
Member#: 59993
Ass, grass or cash
switch batteries maybe? buy a new one? have you called cobb? if it's sayin, "low voltage: check cable" i'd call cobb first.
Old 06-29-2006, 12:41 PM   #15
ErasureWRX
Member#: 106408
'14 Mystery Machine
01 Kat600
I plan on calling them very soon.
I probably should buy another battery, I think mine is on the process of being crap. I have slight corrosion (or buildup?) on the contacts
Old 06-29-2006, 12:49 PM   #16
ErasureWRX
Member#: 106408
'14 Mystery Machine
01 Kat600
They said to replace the battery first.
Guy on the phone didn't sound too pleased to help me
Old 06-29-2006, 01:09 PM   #17
Bishop
Member#: 59993
Ass, grass or cash
did you get a name? they're usually pretty friendly.
Old 06-29-2006, 02:01 PM   #18
ErasureWRX
Member#: 106408
'14 Mystery Machine
01 Kat600
He said his name, except it sounded like he was talking through 20395384lbs of sound deading insulation.
Oh well, I'll just keep havin' at it
Old 06-29-2006, 02:26 PM   #19
Bishop
Member#: 59993
Ass, grass or cash
alright well keep us posted.
Old 06-29-2006, 02:28 PM   #20
johsti
Member#: 36049
2014 FXT Premium
That is the error I used to get, "low voltage...." It might have something to do with your battery, but it might not.
Try this, make sure the car is in test mode (fans and pump cycle intermittently). If your car isn't in test mode, you didn't make the proper connections under the dash. Now, after you select a basemap, the AP will prompt you to turn the ignition off and back on. When you turn the ignition back on does your car stay in test mode? If it doesn't, skip the ignition off/on step, and just press "ok" while your car is in test mode. Some of us had this problem awhile back and this worked for us.
johsti is offline   Reply With Quote
Old 06-29-2006, 02:34 PM   #21
Bishop
Member#: 59993
Ass, grass or cash
man i totally forgot about that issue. sorry it's been almost 2 years since i first flashed.
Old 06-29-2006, 03:08 PM   #22
ErasureWRX
Member#: 106408
'14 Mystery Machine
01 Kat600
Isn't it that only the 04-05's can skip turning it off/on? Or that's what I've been thinking.
Old 06-29-2006, 04:19 PM   #23
johsti
Member#: 36049
2014 FXT Premium
could be.
If your car stays in "test mode" when you turn the ignition off then back on, then this probably won't solve your problem. If it doesn't stay in test mode after turning the ignition back on, then it might be worth trying.
Old 06-29-2006, 04:29 PM   #24
ErasureWRX
Member#: 106408
'14 Mystery Machine
01 Kat600
I will try it later to see if it stays in test mode. Thanks for all the help! If necessary, I will replace my battery this weekend and try yet again
30k service.. where should i go? ragz-rex Mid Atlantic Impreza Club -- MAIC 7 06-03-2010 12:10 PM
What should I pay for an ecu flash? nicholam Commercial ECU Reflashes 14 12-29-2006 10:33 PM
Should parking lights flash? Abe Froman Car Audio, Video & Security 6 11-01-2002 07:30 AM
Turn singnal is flashing faster than it should be...help appreciate... gerardchau General Forum Archive 6 09-02-2000 12:41 AM
