Old 06-25-2006, 01:47 AM   #1
tcspeer
Member#: 113319
1997 Subaru Legacy
Green
Default Brake cable
What is the correct way to remove brake cable from rear drum backing plate on a 98 legacy wagon? Haynes manuel says remove clip but I dont see one. Can the little tabs be raised with small screwdriver and then punched back down without them breaking off?
tcspeer is offline   Reply With Quote
Old 06-25-2006, 10:06 AM   #2
BIGSKYWRX
Member#: 7958
09 GH B+
Are you sure there is no clip? It's a C shaped clip on the back side of the backing plate- there is a small slot on top where it fits as the cable comes out the back side. A small screwdriver works pretty good for popping it out.
If you don't have that not sure how it comes out.
BIGSKYWRX is offline   Reply With Quote
Old 06-25-2006, 11:48 AM   #3
tcspeer
Member#: 113319
1997 Subaru Legacy
Green
I bough it used I guess someone has already lost the clip.
Old 06-26-2006, 09:41 AM   #4
cjfike
Member#: 60116
1999 RS Coupe
Silver Thorn
If you need some, I may have some new ones. Let me know and I will look for them.
cjfike is offline   Reply With Quote
Old 06-26-2006, 10:29 AM   #5
tcspeer
Member#: 113319
1997 Subaru Legacy
Green
Thanks, but this job is going to wait until I need a bearing or axle. Subaru tect told me I could replace backing plate without removing hub. After starting the job I see it cant be done. So I will have time to get them from dealer before I start.
2002 wrx rear brakes, brembo drilled rotors,knuckles, e-brake cables hubs.. Dark WRX Suspension/Brakes/Handling 7 08-22-2008 02:12 PM
Wanted: set of 93 to 01 impreza e brake cables for rear disc brake 2slofouru Private 'Wanted' Classifieds 12 09-13-2006 01:21 AM
wtb hand brake cable for 93-01 for rear disc brakes 2slofouru Private 'Wanted' Classifieds 3 07-16-2006 11:55 PM
i need 4wd impreza with disc brake E-brake Cables. can i modify my cable? supermoose Brakes, Steering & Suspension 0 09-30-2001 09:43 PM
Anyone know how to tighten/replace parking brake cable? byam52 Technical Forum Archive 1 08-17-2000 03:14 PM
Message Board Statistics All times are GMT -4. The time now is 04:02 AM.
