Welcome to the North American Subaru Impreza Owners Club Saturday August 23, 2014
Old 06-26-2006, 12:11 PM   #1
HolyMahwah
Member#: 53936
2008 Leg GT
2004 WRX -> Billy-fied
Default speaker fuzz/static in 1K-2K range
I have a set of Polk db1000 tweeters which are bi-amped with a set of matching 6.5" drivers (also Polks). The passive x-overs which came with the tweeters are wired in-line with them after the amp since the HPF can only be set as high as 500Hz. Amp is a Directed Audio 4600X.
Since putting them in, I can hear a distinct "fuzziness" which is most discernable in the 1-2KHz range. This causes the treble not be clear and distinct...kinda like the way a radio station that is just slightly off-tune will sound.
Anyone have any ideas as to what I should check? I've attempted to narrow down the range in which the "fuzz" appears in by playing with the EQ on the HU, although I can tell it comes from the tweeters and not the woofers. Bad x-over? Bad source? Bad tweeters? I just put them in yesterday, came NIB from a dealer last week, all sealed up.
Thanks,
Dave
HolyMahwah is offline   Reply With Quote
Old 06-27-2006, 12:50 PM   #2
HolyMahwah
Member#: 53936
2008 Leg GT
nada?
Old 06-27-2006, 12:59 PM   #3
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
If you haven't already, maybe you could try to pin it down by disconnecting a tweeter at a time, then swap crossovers (or connections to them). That should at least tell you if the problem is in *one* tweeter or crossover. To see if the problem is in the source, do you have an additional speaker set (or maybe headphones) you could hook up?
Old 06-27-2006, 05:41 PM   #4
tcs007
Member#: 4103
2003 WRX Wagon
Reddish
Are you running two crossover per channel? One active, one passive? Or just the passives?
tcs007 is offline   Reply With Quote
Old 06-28-2006, 10:49 AM   #5
HolyMahwah
Member#: 53936
2008 Leg GT
Both, since the active only goes up to 500Hz. I don't know the exact specs on the Polk x-over, but I would assume it was somewhere in the 3-4kHz range.
Old 06-28-2006, 12:04 PM   #6
eggeegg
Member#: 118769
2006 WRX Sedan
Aspen White, XPT Stage 2
hmmmm
eggeegg is offline   Reply With Quote
Old 06-28-2006, 12:16 PM   #7
HolyMahwah
Member#: 53936
2008 Leg GT
Yeah, I double-checked all the polarities. There don't seem to be any issues with phasing. I'm going to try swapping sources to see if it's coming from the HU itself.
Strange noise between 1k - 2k rpms Nitrous Newbies & FAQs 5 02-09-2008 09:14 PM
My Computer speakers = HORRIBLE static noise OCD-Speed Off-Topic 26 09-27-2007 01:30 PM
Driver Door speakers has static sound then no sound kreddogwrx Car Audio, Video & Security 2 08-06-2007 10:22 AM
static in speakers awdlifestyles Vancouver Impreza Club Forum -- VIC 5 05-30-2006 01:56 AM
Static in speakers munchie Car Audio, Video & Security 0 12-07-2004 09:38 AM
