Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 06-26-2006, 07:59 PM   #1
Tokudai
Member#: 83020
06 WRX Sport Wagon
Crystal Grey Metallic
Default STI ECU in an 06 WRX
Any chance this is a plug and play? I cannot get used to the throttle lag of the 06, and apparently there is no cure.. Since I read less about the problem in the earlier STI's, I got to thinking maybe I could swap ecus, and eliminate the problem. Seems cheaper than removing the whole DBW system... Anyone know if this might work?
Tokudai is offline   Reply With Quote
Old 06-27-2006, 12:11 AM   #2
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
i gotta o6 sti and the boost ramp absolutely sucks............get a utec
mcu81 is offline   Reply With Quote
Old 06-27-2006, 01:14 AM   #3
Tokudai
Member#: 83020
06 WRX Sport Wagon
I was thinking an older STI computer - I don't care so much about the boost curve, I just need to make the car safer and more drivable by fixing the throttle response. I almost went into a ditch yesterday on my dirt road, cause the car didn't slow down and transfer weight when I let off the throttle.
I imagine removing the DBW completely would require a Motec or another complete standalone unit. It doesn't seem possible with the stock ECU, but I wish I could at least see what the throttle is doing when I release it..
Old 06-27-2006, 08:21 AM   #4
JRSCCivic98
Member#: 67080
Aftermarket "flash-type" EM can change the responce factor of the DBW system. Might want to look into that direction... plus you'll gain some drivability and power to boot even without any other mods on the car.
JRSCCivic98 is offline   Reply With Quote
Old 06-27-2006, 08:49 AM   #5
shotoyan
Member#: 35716
2006 WRX
Obsidian Black Pearl
all the current flash-type EM systems change the DBW so that it reacts quicker when opening the throttle. None of them (to my knowledge) change how long the throttle is held open after letting off, which is the problem the OP and many 06 drivers are having difficulty with.
shotoyan is offline   Reply With Quote
USDM sti ECU in an 03 USDM wrx prometheum Engine Management & Tuning 0 02-23-2010 12:58 AM
Will Ver.8 Sti cluster work in an 06 WRX? cppchrisdh Subaru Conversions 3 02-11-2007 10:40 PM
Anyone use an '04 STI ECU in an '05 STI??? JDM-STI Engine Management & Tuning 16 07-16-2006 10:56 PM
Can you put an 06 STi Exhaust on an 06 WRX Wagon? INDY_06_STI Interior & Exterior Modification 3 06-20-2006 09:51 AM
06 sti rims on an 06 wrx junkboxer Tire & Wheel 4 12-29-2005 05:51 PM
