Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2015
Old 06-26-2006, 08:23 PM   #1
kenithzs
Member#: 118270
Default Engine sputter at high RPM?
After about 15 minutes of hard driving at high RPM's, my '00 2.5RS will stall out at around 4500 RPM. It will then run as normal for a few minutes and then sputter out to the point where I cannot get it over 1500 RPM. Once the problem starts it snowballs until the car barely runs, Then I'll let it sit for about 5 minutes and it will run fine for five minutes and then sputter down to low RPM. The next day it will run strong for 15 minutes and then repeat. I pulled the code with the scantool program and it gave me P0463- Fuel Level Sensor High Input. The car was sitting still for a couple of years before I got it so I would not be surprised to find out that the sending units in the tank were hosed before this problem cropped up. If this error is the problem, could a fuel level sensor wreck things this badly?
Assuming that the error code was pre-existing, could these be the symptoms of a fuel pump/relay gone bad? I was thinking that perhaps it is extremly filthy injectors, but then again, why would it only occur after the car gets warmed up?
Thanks, any advice or info would be great.
-Ken
kenithzs is offline   Reply With Quote
Old 06-26-2006, 08:46 PM   #2
borgesxg
Member#: 115643
Do you know what the hardest this about beeing a Subaru owner is ?
borgesxg is offline   Reply With Quote
Old 06-27-2006, 01:18 PM   #3
bryan_johnson
Member#: 78987
bump for curiosity
bryan_johnson is offline   Reply With Quote
Old 06-27-2006, 02:03 PM   #4
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Have you trying to get it up over 4500 by giving it full throotle.
I have had 2 front o2's(a/f meter) go bad without a CEL. They were giving a too low of a voltage reading. It's wold shudder like it wanted to stall out but once I got the RPM's up over 4000-4500 it would excelerate fine.
Patrick L is offline   Reply With Quote
Old 06-29-2006, 06:40 PM   #5
kenithzs
Member#: 118270
Yes when I give it full throttle it will not go above 1000 RPM, its almost as if the RPM govenor is kicking in about 7000 RPM's too soon.
Engine "stutters" at high rpm and after corners? Help please masterpickle Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 09-03-2008 02:57 PM
engine hesitates at high rpm tsukuba speed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-24-2007 05:36 AM
2.2l Engine whistle at high RPM boyleia1 Normally Aspirated Powertrain 11 10-24-2007 04:37 PM
chek engine light at high rpm bigislandracing Off-Topic 18 07-19-2007 07:22 PM
engine sputtering at High Rev full throttle app. outback bosco Service & Maintenance 3 01-26-2002 10:17 PM
