Welcome to the North American Subaru Impreza Owners Club Sunday October 23, 2016
Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 06-26-2006, 09:01 PM   #1
Member#: 42041
2006 WRX STI
aspen white
Default STU STi alignment question: rear toe out?
I see a lot of folks running some rear toe out to aid in rotation. Does this help transitional, steady state or both? How much/little are you guys running?
qcslvr30 is offline   Reply With Quote
Old 06-26-2006, 11:07 PM   #2
Scoobie Doogie
Member#: 9805
2009 Bimmah 135 eye
Does not help in transitionals stuff, yes it could help in steady state. I'm running 0 toe. Heavier springs in the rear and more negative camber up front are better ways of getting rotation.
Dave Mac
Scoobie Doogie is offline   Reply With Quote
Old 06-27-2006, 11:27 AM   #3
Member#: 50200
2004 STi
Hi James:
I went from 1/8" front - neutral rear (last season) to 1/4" front - 1/8" rear (this season), and am liking the latter settings better.
sciolist is offline   Reply With Quote
Old 04-06-2009, 07:34 PM   #4
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
I'm going to bring this thread back to life here because I dialed in 1/4" toe-in in the rear, not toe-out. My car still was a little lose in the transitions/slaloms but is more neutral now. On a skid pad (concrete) it pushes at the limit - 1.02 sustained G, 1.09 peak G which is OK by me. Set up: 8K/6K F/R spring rates, 27-29mm FSB set to 29, 22-24mm RSB set to 24, max -Camber with Cusco plates and OE bolts, and 1/4" front toe out. All and all it feels good. Do other STU STi's dial in a loose rear with toe-out because they push a little at the limit on sweepers?
S1MPSONS is offline   Reply With Quote
Alignment help(accident, toe out, lateral links) ketchupfreak Newbies & FAQs 8 03-26-2009 01:58 PM
went to the alignment shop - rear toe out of spec buds302 Brakes, Steering & Suspension 17 03-03-2009 05:18 PM
Optimal Toe Out for AX'ing STU/STX Subies? makofoto Motorsports 10 01-10-2008 12:26 PM
Alignment toe out, good? bad? v8killer01 Brakes, Steering & Suspension 14 04-22-2006 07:31 AM
Rear toe question: which is worse, both sides evenly wrong or only one side wrong? Sean Brakes, Steering & Suspension 2 10-06-2003 07:23 PM
