Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 06-27-2006, 06:01 PM   #1
cky211
Member#: 31129
02 WRX MPB
No TGV + lots of P&P
Default Low octane map for regular gas is it possible?
with today's gas prices I would like to make a regular gas map for a long trip on the freeway.
I'm thinking CL boost all 5s WGS 0=off
maybe add a little fuel & for timing pull 3 across the board would more be necessary?
Can it be done safely?
I know with my boost map set to all fives I only hit 6 or 7 PSI
Thanks
-Scott
cky211 is offline   Reply With Quote
Old 06-27-2006, 08:51 PM   #2
living4surf
Member#: 85216
it can easly be done as long as boost is low and it is fairly rich
living4surf is offline   Reply With Quote
Old 06-27-2006, 09:45 PM   #3
cky211
Member#: 31129
02 WRX MPB
what AFR would I shoot for?
Old 06-27-2006, 09:48 PM   #4
Division By Zero
Member#: 7555
Yes!!!
Division By Zero is offline   Reply With Quote
Old 06-27-2006, 09:58 PM   #5
living4surf
Member#: 85216
anything near stock numbers should be good and you can probably lean out from there to help save a little more money
Old 06-28-2006, 08:42 AM   #6
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
scott, how are you running the utec?
tps crossover?
open or closed loop fuel?
injector scaling?
Old 06-28-2006, 09:54 AM   #7
Division By Zero
Member#: 7555
If I had a map swithch, I'd easily do an 87 octane map just for the hell of it. Beats the crap out of riding around with a laptop 24/7
Old 06-28-2006, 10:06 AM   #8
TheMadScientist
Member#: 23717
2005 Big red
Build one for ~$4.
All you need is the molex pins, some wire and a SPDT switch. Then you can switch between 2 maps and stock.
TMS
TheMadScientist is offline   Reply With Quote
Old 06-28-2006, 12:47 PM   #9
Division By Zero
Member#: 7555
Originally Posted by TheMadScientist
Build one for ~$4.
TMS
Give me the plans Is it possible to make one with more than two maps?
Old 06-28-2006, 01:22 PM   #10
TheMadScientist
Member#: 23717
2005 Big red
It sure is. You just need to find a switch that has the # of positions you want.
Digikey sells the rotary BDC switch for ~$5, basicly the same one that TXS uses.
Plans?
Take a look at the Utec manual. The molex conector pin out has the pins for each map. You just ground the pins that you want to switch maps too.
TMS
Old 06-28-2006, 03:46 PM   #11
cky211
Member#: 31129
02 WRX MPB
tps crossover?
injector scaling?
tps crossover normal
open loop fuel
yes I have sti injectors. after I did the TGV delete my IDC went sky high so I put the injectors in.
-scott
Old 06-29-2006, 07:33 AM   #12
T-boner
Member#: 57608
All your boost are
belong to us! Mwahahahaaa
Try the Valet (Map 6) map for starters?
T-boner is offline   Reply With Quote
Has anyone swaped there stock Body Panels for 22B Panels? Is it possible? wrxman555 Interior & Exterior Modification 45 04-02-2011 01:26 AM
No Wal-Mart for a month. Is it possible? Tkacik Off-Topic 64 03-02-2008 11:06 AM
Is it possible to tell if synthetic or regular oil was used in the motor? Osgood30 Subaru Conversions 3 09-29-2005 03:35 PM
H6 3.0 or EJ20 for 4EAT : is it possible? aek Normally Aspirated Powertrain 8 03-25-2002 07:41 PM
2002 WRX Want To Run Mid 12's For $4,000, is it possible Uthinkso Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 11-25-2001 04:18 PM
