Welcome to the North American Subaru Impreza Owners Club Sunday March 1, 2015
Old 10-17-2001, 05:45 PM   #1
Singletracksean
Member#: 656
98 Impreza L Wagon
Acadia Green
Default Turbo 2.2L Hood options?
Ok, aluminium, stock RS, or carbon fiber? These are the options I'm aware of. Are there any others? Can you paint a carbon hood? Seems like a waste of carbon, but I dont think I like the look. I like the aluminum option best, but may lean towrds the stock new or used RS/OBS due to cost. Any pros or cons like air flow to the intercooler.
Thanks for any ideas, just ordered a turbo kit and need to round up a few things.
Sean
Singletracksean is offline   Reply With Quote
Old 10-17-2001, 10:35 PM   #2
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
You can have carbon fiber painted, but you're adding the weight of the paint.
LVSUBARU is offline   Reply With Quote
Old 10-18-2001, 02:21 AM   #3
SoobATV
Member#: 6883
MY04 Foz XS
MY02 Imp TS
I'd say get a painted CF hood... probably still weighs less than the stock RS hood.
SoobATV is offline   Reply With Quote
Old 10-18-2001, 10:35 AM   #4
bill harvey
Member#: 10
2005 Legacy Gt wagon
Garnet red pearl
I say stay away from carbon fiber because it will not crumple in an accident it will just remove your head for you
bill harvey is offline   Reply With Quote
Old 10-19-2001, 09:54 AM   #5
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
remember the aluminum hood can dent easily, ie: hail storm
the carbon fiber will need pins to help keep it down at highway speeds
Scoobyslack1 is offline   Reply With Quote
Old 10-19-2001, 10:45 AM   #6
synapse79
Guest
Member#:
I had a carbon hood on a dark blue integra and it looked really good, there is something about seeing that much polished carbon fiber all at once..
there were a few problems though, the biggest problem is that it will flutter like butterfly wings around 80 to 100mph, mine even had fiberglass bracing on the inside.. the other problem is it draws lots of attention, i hope you live in an area with a low crime rate.
I would get an aluminium hood, because it wouldn't flex like the carbon hood, and most carbon hoods i've seen are polished, if you wanted to paint it, you would have to find one that isn't polished. Mine had a polished gel cout finish and it stood up to scratches really well.. well i guess you could sand the hell out of it too..
the other thing to consider, is there is an abundance of al hoods out there.. i have yet to see a carbon hood for a subaru.. i think functionaly, the Al hood is going to be better.. Carbon hood is prettier, if you like that look, but more hassle..
Old 10-19-2001, 11:20 AM   #7
mhj
Member#: 3057
Does anyone make a fiberglass hood? I imagine it'd be lighter than stock (depending on # of layers of course) and pretty cheap to make.
mhj is offline   Reply With Quote
98 2.2L gearset option ride4fun05 Subaru Conversions 12 10-12-2005 01:13 PM
Questions on turboed 2.2L? Is this safe to do or would a swap be better? k2snow Normally Aspirated with bolt-on Forced Induction Powertrain 18 03-19-2003 12:07 PM
2.2L exhaust options k2snow Normally Aspirated Powertrain 29 09-30-2002 12:14 PM
turbo 2.2L imprezaLRX Normally Aspirated with bolt-on Forced Induction Powertrain 8 09-16-2002 01:16 PM
Turbo 2.2l, need advice mikec Normally Aspirated with bolt-on Forced Induction Powertrain 3 10-04-2001 08:38 PM
