Old 06-27-2006, 09:49 PM   #1
joeyd02
Member#: 16742
07 STI UGM
AP Stage2 Clark Tuned
Default ECU reflashed. Gettin 2 much fuel
I sent my ECU in for an ECUTEK reflash. I just got it back today. It starts , but seems to be getting too much fuel. The car hits 1k RPM then when I let off it just stalls.I pulled out a spark plug and it was wet from fuel. It was tuned for 816cc injectors. If I threw in the STi 550cc injectors would it help out the fuel issue? Like to lean it out some?
joeyd02 is offline   Reply With Quote
Old 06-28-2006, 01:58 PM   #2
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
What was the map designed for? If it was designed around STi injectors then you will be ok. If not then you will run too lean.
Cheers,
Crawford Performance / I-Speed USA
Crawford/I-Speed is offline   Reply With Quote
Ecu Reflash on 2.5i? deezy1987 AccessPort 4 01-01-2008 10:16 PM
ECU reflash for fuel econ + UTEC? aznatama UTEC 19 11-20-2006 07:41 PM
how much for stock ecu reflash? Spooled Vancouver Impreza Club Forum -- VIC 9 06-11-2006 12:08 AM
MI: 02 Cobb ECU Reflash Stage 2, 91Oct myton78 Private 'For Sale' Classifieds 6 03-24-2004 01:29 PM
Anyone using a reflashed ECU in a 2.5RS-T? Jon Bogert Normally Aspirated with bolt-on Forced Induction Powertrain 42 12-13-2003 02:09 AM
