Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 10-17-2001, 06:17 PM   #1
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Default How to make high beams work independantly of low beams?
Anyone?
-Alex
Imprezer is offline   Reply With Quote
Old 10-17-2001, 08:31 PM   #2
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
On morettes maybe? Maybe you can wire in the high beams to another switch......
Andres
ATX25RS is offline   Reply With Quote
Old 10-17-2001, 08:43 PM   #3
sti2_5rs
Member#: 1578
2000 Impreza 2.5RS
you have morettes and HID combo?
sti2_5rs is offline   Reply With Quote
Old 10-17-2001, 10:05 PM   #4
LttLDGN
Member#: 5478
um... it will only work if you have separate lights on your headlight... which means you will need morette's or japanese spec headlights ( need 2 separate driving lights)
after that.....
look at the headlight connectors...... it should have 3 connectors...
one is the POS for lo-beams one is POS for hi-beam
and the other is the NEG ground. You will have to get separate connectors for the 2 headlights to be used (one for hi, one for low)
then you will have to cut your original headlight harness.....
find out which wires power the hi-beams and connect(solder) that to the new light plug. same goes for the lo-beams... you can either choose to ground the extra lights to the car or to splice the original ground wire.
to find out which wire is hi-beam and which is low, use a voltmeter, and connect 1 wire to unknown wire, other to ground... turn lights on...
the instructions above let you have separate hi-beams, but will turn off the lo beam lights when hi-beam is on and vice versa....
if you want to be able to have BOTH on, you can either wire a completely separate switch or splice the hi-beam wires again so they power the lo-beam lights.... be advised, the lo beam bulbs must be able to take the extra wattage.... =)
hope my crappy instructions helped... if not, just PM or mail me =)
Jerome
LttLDGN is offline   Reply With Quote
Old 10-17-2001, 10:57 PM   #5
TaiChih
Member#: 3467
1998 Dinan3
Bleck
That makes sense, but can't you just locate the low bwam cutoff relay for the high beams, and just bypass it? I'm having the same problem of trying to get my low beam (HID's) NOT to cut out when I turn on the high's
TaiChih is offline   Reply With Quote
Old 10-17-2001, 11:49 PM   #6
go go go
Member#: 2784
I need a help on this, too. Anybody?
I also want to know if it is possible to light up lo-hi-fog altogether without electrical failure.
go go go is offline   Reply With Quote
Old 10-18-2001, 01:02 AM   #7
Imprezer
Dynamic Uno
Member#: 1
I need to do what TaiChih said.
I have STi HID's and want the low beams stay one when I flash someone.
-Alex
Old 10-18-2001, 01:47 AM   #8
LttLDGN
Member#: 5478
OhhHhHhh hehehe
so... do you guys have different wiring harnesses for the lights???
what Tai-chi mentioned would probably be the easiest route....
you COULD try splicing the hi beam wires so they also lead to the lo-beams... although that may make the lo beams flash as well..... =T ...hrmmm.. sorry i can't help as i have no idea what your harnesses look like GL~!!
Old 10-18-2001, 02:12 AM   #9
TaiChih
Member#: 3467
1998 Dinan3
Bleck
DAMN IT! I'm going to figure this out eventually. Do we have any electrical engineers? I could go to the stealership and get the wiring diagram for the lights
Old 10-18-2001, 02:29 AM   #10
LttLDGN
Member#: 5478
stealership??!!
j/k man...hehe couldn't resist.... i'm no EE but..... i am pretty good at electrical/mechanical stuff....
do you have the same wiring harness as the stock WRX? if so, i don't mind digging into my engine bay a bit and checking it out. =)
btw... i noticed you're a fellow MD'er ... where from?
i haven't gone to any MD meets yet... but was thinking about heading to Hot Shots sometime... or the big D&B meet... =T i'll see
oh... i'm in Silver Spring btw..
Old 10-18-2001, 02:38 AM   #11
TaiChih
Member#: 3467
1998 Dinan3
Bleck
Slver Spring
Old 10-30-2001, 10:22 PM   #12
pakman916
Member#: 11593
2002 WRX Wagon
Midnight Black
I know this may not be as significant to the two Marylanders...but I also was from MD. I moved to Seattle after graduating from UM. Just wanted to say hello to fellow marylanders. Good to hear people from my hometown.
My folks still live in Potomac...
pakman916 is offline   Reply With Quote
Old 10-30-2001, 10:53 PM   #13
daverup
Member#: 3708
2015 WRX Ltd Sedan
ISM
I bought a set of Morrettes, and they came with a relay setup to keep the low beams on when the high beams are on.
The low beams actually are off momentarily when the switch is thrown on the column. This pissed off my HID's quite a bit, so I ended up using a couple of big capacitors to keep the HID power relays engaged even when power drops momentarily.
daverup is offline   Reply With Quote
Old 10-30-2001, 11:02 PM   #14
TaiChih
Member#: 3467
1998 Dinan3
Bleck
hi pakman! hey Daverup, That's what I was hoping to avoid about the HID's, the momentary cutoff. It's bad for the HID's.
how to disconnect daylight driving lights but have low beams? scoobypuff Interior & Exterior Modification 25 04-19-2010 11:09 PM
Tell me how to make $100/day working from home. Captain TinklePee Off-Topic 61 01-22-2009 03:25 AM
Netapp folks: how to make a spare drive part of aggregate? -=C=- Off-Topic 3 09-19-2008 03:51 PM
How to make a trucker hat out of garbage.. soundwave Off-Topic 2 09-17-2003 02:16 PM
How to make STi engine work with 4EAT? garface Transmission (AT/MT) & Driveline 12 02-22-2002 12:00 AM
